Issue Update to 0.98.2
Hi All,
Can someone help my to explan this error…
19-09-03 11:57:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:08 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:10 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-03 11:57:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:15 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-09-03 11:57:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:23 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:28 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:30 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-09-03 11:57:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-09-03 11:57:35 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-09-03 11:57:35 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.98.1
19-09-03 11:57:35 INFO (SyncWorker_8) [hassio.docker.interface] Cleanup images: [‘homeassistant/qemux86-64-homeassistant:0.98.2’]
19-09-03 11:57:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-09-03 11:57:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-09-03 11:57:38 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-09-03 11:57:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-09-03 12:14:24 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-09-03 12:42:30 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
due to some reason, it is not possible to update. I also had this last time. Then I turned off hassio addons. But that should not be the intention.
