I was wondering if other encountered similar problem and if yes, what steps did you take to go around it. I am powering my LD2410 with Wemos d1 3.3v pin. I noticed that it fails updating wirelessly unless I disconnect the LD2410 power. is it due to some UART conflict or power draw during update?
code:
esphome:
friendly_name: familyroom-ld2410c-bh1750
esp8266:
board: d1_mini
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "cIx9py95ze2mbu0n98BwEjJlMm/mEMnsCipQdhXh/TQ="
ota:
password: "3df9acc3efdab7b2cb592e5947e566fe"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Familyroom-Ld2410C-Bh1750"
password: "5ma9KPVDAnne"
captive_portal:
globals:
- id: last_illuminance
type: float
restore_value: no
initial_value: "-1"
i2c:
sda: D2
scl: D1
ld2410:
uart:
tx_pin: TX
rx_pin: RX
baud_rate: 256000
parity: NONE
stop_bits: 1
binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
############# BH1750 - Light sensor ################
- platform: bh1750
address: 0x23
accuracy_decimals: 1
update_interval: 1s
filters:
- lambda: !lambda |-
if (id(last_illuminance) == x){
return {};
if (abs(id(last_illuminance) - x) > 1){
id(last_illuminance) = x;
return x;
return {};
############# LD2410C - mmWave sensor ################
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control bluetooth"
number:
- platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
button:
- platform: ld2410
factory_reset:
restart:
query_params:
text_sensor:
- platform: ld2410
version:
mac_address:
select:
- platform: ld2410
distance_resolution:
name: "distance resolution"
baud_rate:
light_function:
out_pin_level:
name: out pin level
