Hello, I am new to developing integrations and I am having an issue that i am not being able to resolve.
When configuring a new hub on my integration it just displays two new devices found, when in reality it has created 11, i can only see them if I refresh the webpage.
Here it is my init.py, coordinator.py and sensor.py
__init__.py
"""The ista Calista integration."""
from __future__ import annotations
import logging
from pycalista_ista import LoginError, PyCalistaIsta, ServerError
from homeassistant.components.recorder import get_instance
from homeassistant.const import CONF_EMAIL, CONF_PASSWORD, Platform
from homeassistant.core import HomeAssistant
from homeassistant.exceptions import ConfigEntryAuthFailed, ConfigEntryNotReady
from .const import DOMAIN
from .coordinator import IstaConfigEntry, IstaCoordinator
# Set up logging
LOGGER = logging.getLogger(__name__)
PLATFORMS: list[Platform] = [Platform.SENSOR]
async def async_setup_entry(hass: HomeAssistant, entry: IstaConfigEntry) -> bool:
"""Setup the ista Calista integration.
Args:
hass: The Home Assistant instance.
entry: The config entry to setup.
Returns:
True if setup was successful, False otherwise.
Raises:
ConfigEntryNotReady: If unable to connect to ista Calista.
ConfigEntryAuthFailed: If authentication fails.
LOGGER.debug("Setting up ista Calista integration")
ista = PyCalistaIsta(
entry.data[CONF_EMAIL],
entry.data[CONF_PASSWORD],
try:
LOGGER.info("Attempting to login to ista Calista")
await hass.async_add_executor_job(ista.login)
LOGGER.info("Login to ista Calista successful")
except ServerError as e:
LOGGER.error("Connection to ista Calista failed: %s", str(e))
raise ConfigEntryNotReady(
translation_domain=DOMAIN,
translation_key="connection_exception",
) from e
except LoginError as e:
LOGGER.error(
"Authentication to ista Calista failed for %s: %s",
str(e),
raise ConfigEntryAuthFailed(
translation_key="authentication_exception",
translation_placeholders={CONF_EMAIL: entry.data[CONF_EMAIL]},
) from e
coordinator = IstaCoordinator(hass, entry, ista)
# Do the first refresh before setting up platforms
try:
LOGGER.info("Performing initial data refresh")
await coordinator.async_config_entry_first_refresh()
LOGGER.debug("Initial data refresh successful")
except ConfigEntryNotReady as err:
LOGGER.error("Failed to load initial data: %s", str(err))
raise ConfigEntryNotReady("Failed to load initial data") from err
entry.runtime_data = coordinator
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
return True
async def async_unload_entry(hass: HomeAssistant, entry: IstaConfigEntry) -> bool:
"""Unload a config entry."""
LOGGER.info("Unloading ista Calista integration")
statistic_ids = [f"{DOMAIN}:{name}" for name in entry.options.values()]
LOGGER.debug("Clearing statistics: %s", statistic_ids)
get_instance(hass).async_clear_statistics(statistic_ids)
result = await hass.config_entries.async_unload_platforms(entry, PLATFORMS)
LOGGER.info("ista Calista integration unloaded: %s", result)
return result
coordinator.py
"""DataUpdateCoordinator for Ista Calista integration."""
from datetime import date, datetime, timedelta
import logging
from typing import TypedDict
from pycalista_ista import Device, LoginError, PyCalistaIsta, ServerError
from homeassistant.config_entries import ConfigEntry
from homeassistant.const import CONF_EMAIL, CONF_OFFSET
from homeassistant.helpers.update_coordinator import DataUpdateCoordinator, UpdateFailed
_LOGGER = logging.getLogger(__name__)
_LOGGER.setLevel("DEBUG")
type IstaConfigEntry = ConfigEntry[IstaCoordinator]
class IstaDeviceData(TypedDict):
"""Ista device data."""
devices: dict[str, Device]
last_update: date
class IstaCoordinator(DataUpdateCoordinator[IstaDeviceData]):
"""Ista Calista data update coordinator."""
config_entry: IstaConfigEntry
def __init__(
self, hass: HomeAssistant, config_entry: IstaConfigEntry, ista: PyCalistaIsta
) -> None:
"""Initialize ista Calista data update coordinator."""
self.coordinator_id = f"coordinator_{config_entry.entry_id[:8]}"
_LOGGER.debug(
"[%s] Initializing Ista coordinator with config entry ID: %s",
self.coordinator_id,
config_entry.entry_id,
super().__init__(
hass,
_LOGGER,
config_entry=config_entry,
name=DOMAIN,
update_interval=timedelta(days=1),
self.ista = ista
self.details: IstaDeviceData = {}
_LOGGER.debug(
"[%s] Coordinator initialized with update interval",
self.coordinator_id
async def _async_update_data(self) -> IstaDeviceData:
"""Fetch ista Calista data.
Returns:
A dictionary containing device data and last update timestamp.
Raises:
UpdateFailed: If server is unreachable or returns invalid data.
_LOGGER.debug("[%s] Starting data update", self.coordinator_id)
try:
_LOGGER.debug("[%s] Attempting login to Ista Calista", self.coordinator_id)
await self.hass.async_add_executor_job(self.ista.login)
_LOGGER.debug("[%s] Login successful", self.coordinator_id)
if not self.details:
_LOGGER.debug(
"[%s] No existing details, fetching full history",
self.details = await self.async_get_details(init=True)
else:
_LOGGER.debug("[%s] Updating existing details", self.coordinator_id)
self.details = await self.async_get_details()
device_count = (
len(self.details["devices"]) if self.details.get("devices") else 0
_LOGGER.debug(
"[%s] Retrieved %d devices", self.coordinator_id, device_count
if not self.details["devices"]:
_LOGGER.error(
"[%s] No devices found in Ista Calista account", self.coordinator_id
raise UpdateFailed("No devices found in ista Calista account")
_LOGGER.info(
"[%s] Successfully updated data with %d devices, last update: %s",
device_count,
self.details["last_update"],
return self.details
except ServerError as err:
_LOGGER.error(
"[%s] Server error while connecting to Ista Calista: %s",
str(err),
raise UpdateFailed(
"Unable to connect and retrieve data from ista Calista, try again later"
) from err
except LoginError as err:
_LOGGER.error(
"[%s] Authentication failed for account %s: %s",
self.config_entry.data[CONF_EMAIL],
str(err),
CONF_EMAIL: self.config_entry.data[CONF_EMAIL]
) from err
except Exception as err:
_LOGGER.exception(
"[%s] Unexpected error occurred while updating Ista Calista data: %s",
str(err),
raise UpdateFailed(f"Unexpected error: {err}") from err
async def async_get_details(self, init: bool = False) -> IstaDeviceData:
"""Retrieve details of consumption units."""
configured_init_date = datetime.strptime(
self.config_entry.data[CONF_OFFSET], "%Y-%m-%d"
).date()
if init:
_LOGGER.debug(
"[%s] Fetching full device history since %s",
configured_init_date,
result = await self.hass.async_add_executor_job(
self.ista.get_devices_history, configured_init_date
else:
fetch_date = max(configured_init_date, date.today() - timedelta(days=30))
_LOGGER.debug(
"[%s] Fetching incremental device history since %s",
fetch_date,
self.ista.get_devices_history, fetch_date
# Log details about each device retrieved
for serial, device in result.items():
_LOGGER.debug(
"[%s] Retrieved device - Serial: %s, Type: %s, Location: %s, Readings: %d",
serial,
type(device).__name__,
device.location,
len(device.history) if device.history else 0,
current_time = datetime.now()
_LOGGER.debug(
"[%s] Completed fetching details at %s with %d devices",
current_time,
len(result),
return {"devices": result, "last_update": current_time}
timedelta(days=1),
sensor.py
from collections.abc import Callable
from dataclasses import dataclass
from datetime import UTC, datetime, timedelta
from enum import StrEnum
import logging
from typing import Final
from pycalista_ista import ColdWaterDevice, Device, HeatingDevice, HotWaterDevice
from homeassistant.components.recorder.models.statistics import (
StatisticData,
StatisticMetaData,
from homeassistant.components.recorder.statistics import (
async_add_external_statistics,
get_instance,
get_last_statistics,
from homeassistant.components.sensor import (
SensorDeviceClass,
SensorEntity,
SensorEntityDescription,
SensorStateClass,
from homeassistant.const import STATE_UNKNOWN, EntityCategory, UnitOfVolume
from homeassistant.core import HomeAssistant, callback
from homeassistant.helpers.device_registry import DeviceEntry, DeviceInfo
from homeassistant.helpers.entity_platform import AddEntitiesCallback
from homeassistant.helpers.typing import StateType
from homeassistant.helpers.update_coordinator import CoordinatorEntity
from .const import DOMAIN, MANUFACTURER
# Enhanced logging configuration
_LOGGER: Final = logging.getLogger(__name__)
# Coordinator is used to centralize the data updates
PARALLEL_UPDATES = 0
class IstaSensorEntity(StrEnum):
"""Ista EcoTrend Entities."""
HEATING = "heating"
HOT_WATER = "hot_water"
WATER = "water"
LAST_READING = "last_reading"
@dataclass(frozen=True, kw_only=True)
class CalistaSensorEntityDescription(SensorEntityDescription):
"""Describes an Ista Calista sensor entity.
Attributes:
exists_fn: Function to determine if this sensor type exists for a given device
value_fn: Function to extract the sensor value from a device
generate_lts: Whether to generate long-term statistics for this sensor
entity_category: Entity category for the sensor
exists_fn: Callable[[Device], bool] = lambda _: True
value_fn: Callable[[Device], StateType]
generate_lts: bool
entity_category: EntityCategory | None = None
SENSOR_DESCRIPTIONS: Final[tuple[CalistaSensorEntityDescription, ...]] = (
key=IstaSensorEntity.WATER,
translation_key=IstaSensorEntity.WATER,
native_unit_of_measurement=UnitOfVolume.CUBIC_METERS,
device_class=SensorDeviceClass.WATER,
state_class=SensorStateClass.TOTAL_INCREASING,
suggested_display_precision=2,
value_fn=lambda device: (
device.last_reading.reading if device.last_reading else None
exists_fn=lambda device: isinstance(device, ColdWaterDevice),
generate_lts=True,
has_entity_name=True,
key=IstaSensorEntity.HOT_WATER,
translation_key=IstaSensorEntity.HOT_WATER,
exists_fn=lambda device: isinstance(device, HotWaterDevice),
generate_lts=True,
key=IstaSensorEntity.HEATING,
translation_key=IstaSensorEntity.HEATING,
device_class=SensorDeviceClass.GAS,
exists_fn=lambda device: isinstance(device, HeatingDevice),
generate_lts=True,
key=IstaSensorEntity.LAST_READING,
translation_key=IstaSensorEntity.LAST_READING,
device_class=SensorDeviceClass.TIMESTAMP,
device.last_reading.date if device.last_reading else None
exists_fn=lambda device: isinstance(device, Device),
generate_lts=False,
entity_category=EntityCategory.DIAGNOSTIC,
async_add_entities: AddEntitiesCallback,
) -> None:
"""Set up Ista Calista sensors based on a config entry.
Args:
config_entry: The config entry being set up.
async_add_entities: Callback to register new entities.
coordinator = config_entry.runtime_data
_LOGGER.debug("Setting up Ista Calista sensors with coordinator: %s", coordinator)
# Log device information
device_count = len(coordinator.data["devices"])
_LOGGER.debug("Found %d devices in coordinator data", device_count)
for serial_number, device in coordinator.data["devices"].items():
_LOGGER.debug(
"Device found - Serial: %s, Type: %s, Location: %s, Has readings: %s",
serial_number,
device.location,
bool(device.last_reading),
entities = []
for description in SENSOR_DESCRIPTIONS:
if description.exists_fn(device):
entity_id = f"{serial_number}_{description.key}"
_LOGGER.debug(
"[%s] Creating sensor - Serial: %s, Type: %s, Description: %s",
entity_id,
serial_number,
description.key,
entities.append(IstaSensor(coordinator, serial_number, description))
_LOGGER.info("Adding %d Ista Calista sensor entities", len(entities))
async_add_entities(entities)
class IstaSensor(CoordinatorEntity[IstaCoordinator], SensorEntity):
"""Representation of an Ista Calista sensor.
This sensor entity represents various types of utility consumption meters
from Ista Calista, including water and heating meters. It supports real-time
readings and historical data tracking.
Attributes:
entity_description: Description of the sensor entity
_attr_has_entity_name: Whether the entity has a friendly name
device_entry: Associated device entry in the device registry
entity_description: CalistaSensorEntityDescription
_attr_has_entity_name = True
device_entry: DeviceEntry
@property
def device_info(self) -> DeviceInfo:
"""Return device information about this entity.
Returns:
Device information for the device registry.
device = self.coordinator.data["devices"][self.serial_number]
device_info = DeviceInfo(
identifiers={(DOMAIN, self.serial_number)},
name=self._generate_name(device),
manufacturer=MANUFACTURER,
model="ista Calista",
sw_version=self.coordinator.config_entry.version,
configuration_url="https://oficina.ista.es/GesCon/MainPageAbo.do",
_LOGGER.debug(
"[%s] Device info for %s: name=%s, area=%s",
self._attr_unique_id,
self.serial_number,
device_info["name"],
device_info.get("suggested_area"),
return device_info
def _generate_name(self, device: Device) -> str:
"""Generate a friendly name for the device.
Args:
device: The device to generate a name for.
Returns:
A user-friendly name based on the device type and location.
if device.location:
return device.location
if isinstance(device, ColdWaterDevice):
return "Water"
if isinstance(device, HotWaterDevice):
return "Hot water"
if isinstance(device, HeatingDevice):
return "Heating"
return "Unknown"
def __init__(
self,
coordinator: IstaCoordinator,
serial_number: str,
entity_description: CalistaSensorEntityDescription,
) -> None:
"""Initialize the Ista Calista sensor.
Args:
coordinator: The data update coordinator
serial_number: Unique serial number of the device
super().__init__(coordinator)
self.serial_number = serial_number
self._attr_unique_id = f"{serial_number}_{entity_description.key}"
self.entity_description = entity_description
self._attr_entity_category = entity_description.entity_category
_LOGGER.debug(
"[%s] Initialized IstaSensor - Serial: %s, Entity ID: %s, Type: %s",
serial_number,
entity_description.key,
@property
def native_value(self) -> StateType | datetime:
"""Return the state of the sensor.
Returns:
The current state value of the sensor, or STATE_UNKNOWN if no data available.
try:
value = self.entity_description.value_fn(device)
return value if value is not None else STATE_UNKNOWN
_LOGGER.error(
"[%s] Error getting native value for %s: %s",
str(err),
exc_info=True,
return STATE_UNKNOWN
async def async_added_to_hass(self) -> None:
"""Handle entity which will be added.
Performs initial statistics import when sensor is added to avoid
waiting for the first coordinator update.
_LOGGER.debug(
"[%s] Entity description details - Key: %s, Generate LTS: %s",
self.entity_description.key,
self.entity_description.generate_lts,
if self.entity_description.generate_lts:
_LOGGER.debug(
"[%s] Generating initial statistics for %s",
await self._update_statistics()
else:
_LOGGER.debug(
"[%s] Skipping statistics generation for %s (not enabled)",
await super().async_added_to_hass()
@callback
async def _handle_coordinator_update(self) -> None:
"""Handle updated data from the coordinator.
Updates statistics if enabled for this sensor.
_LOGGER.debug(
"[%s] Coordinator update for %s", self._attr_unique_id, self._attr_unique_id
_LOGGER.debug(
"[%s] Scheduling statistics update for %s",
super()._handle_coordinator_update()
def _update_statistics(self) -> None:
"""Import historical statistics from Ista Calista.
This method processes historical readings and generates long-term statistics
for the sensor, including total consumption and state history.
try:
_LOGGER.debug(
"[%s] Updating statistics for %s",
# Get the saved statistics name or generate one
name = self.coordinator.config_entry.options.get(
f"lts_{self.entity_description.key}_{self.serial_number}"
if not name:
name = self.entity_id.removeprefix("sensor.")
_LOGGER.debug(
"[%s] No saved statistics name for %s, using %s",
name,
self.hass.config_entries.async_update_entry(
entry=self.coordinator.config_entry,
options={
**self.coordinator.config_entry.options,
f"lts_{self.entity_description.key}_{self.serial_number}": name,
statistic_id = f"{DOMAIN}:{name}"
_LOGGER.debug("[%s] Statistics ID: %s", self._attr_unique_id, statistic_id)
# Get device history
history = device.history
if not history:
_LOGGER.warning(
"[%s] No history available for %s",
return
_LOGGER.debug(
"[%s] Found %d historical readings for %s",
len(history),
# Get last statistics from database
last_stats = get_instance(self.hass).async_add_executor_job(
self.hass,
1,
statistic_id,
False,
{"sum", "state", "last_reset"},
if last_stats and statistic_id in last_stats:
_LOGGER.debug(
"[%s] Found existing statistics for %s",
statistic_id,
last_stats_sum = last_stats[statistic_id][0].get("sum") or 0.0
last_stats_state = last_stats[statistic_id][0].get("state") or None
last_stats_last_reset = datetime.fromtimestamp(
last_stats[statistic_id][0].get("last_reset") or 0, tz=UTC
last_stats_date = datetime.fromtimestamp(
last_stats[statistic_id][0].get("end") or 0, tz=UTC
) + timedelta(days=1)
else:
last_stats_sum = 0.0
last_stats_state = None
last_stats_date = None
last_stats_last_reset = history[0].date
_LOGGER.debug(
"[%s] No existing statistics found for %s",
statistic_id,
_LOGGER.debug(
"[%s] Last statistics - Sum: %f, State: %s, Last Reset: %s, Date: %s",
last_stats_sum,
last_stats_state,
last_stats_last_reset,
last_stats_date,
readings_after_last_stats = [
reading
for reading in history
if last_stats_date is None or reading.date > last_stats_date
# Process history and build statistics
joined_history = []
for i, reading in enumerate(readings_after_last_stats):
current_reading = reading.reading
previous_reading = (
readings_after_last_stats[i - 1].reading
if i > 0
else last_stats_state
if previous_reading is None:
previous_reading = current_reading
# Check for meter reset
if previous_reading > current_reading:
_LOGGER.debug(
"[%s] Meter reset detected at %s",
reading.date,
last_stats_last_reset = reading.date
consumption = 0
else:
consumption = current_reading - previous_reading
last_stats_sum += consumption
_LOGGER.debug(
"[%s] Adding history point - Date: %s, Reading: %f, Last Reset: %s, Sum: %f",
reading.date.isoformat(),
current_reading,
last_stats_last_reset.isoformat(),
last_stats_sum,
joined_history.append(
"date": reading.date,
"current_reading": current_reading,
"last_reset": last_stats_last_reset,
"statistics_sum_diff": last_stats_sum,
_LOGGER.debug("[%s]%s", self._attr_unique_id, reading.date)
# Create statistics entries
statistics: list[StatisticData] = [
"start": history_data["date"],
"state": history_data["current_reading"],
"sum": history_data["statistics_sum_diff"],
"last_reset": history_data["last_reset"],
for history_data in joined_history
if last_stats_date is None or history_data["date"] > last_stats_date
# Create statistics metadata
metadata: StatisticMetaData = {
"has_mean": False,
"has_sum": True,
"name": f"{self._generate_name(device)} {self.name}",
"source": DOMAIN,
"statistic_id": statistic_id,
"unit_of_measurement": self.entity_description.native_unit_of_measurement,
if statistics:
_LOGGER.info(
"[%s] Inserting %d statistics entries for %s",
len(statistics),
statistic_id,
_LOGGER.debug(
"[%s] Statistics metadata: %s", self._attr_unique_id, metadata
_LOGGER.debug(
"[%s] First statistics entry: %s",
statistics[0],
_LOGGER.debug(
"[%s] Last statistics entry: %s",
statistics[-1],
async_add_external_statistics(self.hass, metadata, statistics)
else:
_LOGGER.debug(
"[%s] No new statistics to insert for %s",
statistic_id,
except Exception:
_LOGGER.exception(
"[%s] Error updating statistics for %s:",
Thanks!!
