HA ver 0.41, python 3.5.3
In raspberry the android ip webcam works fine
In windows 10 (32 or 64) not works
I have tried install pydroid-ipcam and multidict separately with sucess but nothing
I tried give right to Everyone for .hommeasistant and python35 folders but the sames results
configuration file:
homeassistant:
latitude: 37.8
longitude: 21.35
elevation: 5
unit_system: metric
time_zone: Europe/Athens
frontend:
android_ip_webcam:
- host: 192.168.1.10
output:
INFO:homeassistant.bootstrap:Home Assistant core initialized
INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
INFO:homeassistant.loader:Loaded api from homeassistant.components.api
INFO:homeassistant.loader:Loaded http from homeassistant.components.http
INFO:homeassistant.loader:Loaded websocket_api from homeassistant.components.websocket_api
INFO:homeassistant.loader:Loaded android_ip_webcam from homeassistant.components.android_ip_webcam
INFO:homeassistant.util.package:Attempting install of pydroid-ipcam==0.6
Exception:
File “c:\users\lam\appdata\local\programs\python\python35-32\lib\site-packages\pip\basecommand.py”, line 215, in main
status = self.run(options, args)
File “c:\users\lam\appdata\local\programs\python\python35-32\lib\site-packages\pip\commands\install.py”, line 423, in run
shutil.rmtree(target_item_dir)
File “c:\users\lam\appdata\local\programs\python\python35-32\lib\shutil.py”, line 488, in rmtree
return _rmtree_unsafe(path, onerror)
File “c:\users\lam\appdata\local\programs\python\python35-32\lib\shutil.py”, line 383, in _rmtree_unsafe
onerror(os.unlink, fullname, sys.exc_info())
File “c:\users\lam\appdata\local\programs\python\python35-32\lib\shutil.py”, line 381, in _rmtree_unsafe
os.unlink(fullname)
PermissionError: [WinError 5] Access is denied: ‘C:\Users\lam\AppData\Roaming\.homeassistant\deps\multidict\_multidict.cp35-win32.pyd’
ERROR:homeassistant.setup:Not initializing android_ip_webcam because could not install dependency pydroid-ipcam==0.6
ERROR:homeassistant.setup:Setup failed for android_ip_webcam: Could not install all requirements.
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=persistent_notification, service_data=title=Invalid config, notification_id=invalid_config, message=The following components and platforms could not be set up:
- android_ip_webcam
Please check your config, service=create, service_call_id=53223344-1>
INFO:homeassistant.core:Bus:Handling <Event call_service[L]: domain=persistent_notification, service_data=title=Invalid config, notification_id=invalid_config, message=The following components and platforms could not be set up: -
android-ip-webcam
Please check your config, service=create, service_call_id=53223344-2>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up: - android_ip_webcam
Please check your config; title=Invalid config @ 2017-04-04T08:50:26.173030+03:00>>
INFO:homeassistant.core:Bus:Handling <Event service_executed[L]: service_call_id=53223344-1>
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up: - android_ip_webcam
Please check your config; title=Invalid config @ 2017-04-04T08:50:26.173030+03:00>, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up: - android-ip-webcam
