Of course there is attempt 1/3, 2/3 and 3/3, but after this:
2020-02-07 17:29:47 INFO (MainThread) [homeassistant.setup] Setup of domain arlo took 1.1 seconds.
2020-02-07 17:29:47 ERROR (MainThread) [homeassistant.setup] Setup failed for arlo: Integration failed to initialize.
Just to be precise: I have an Arlo Q but no other cameras or base.
Any success with this? Lately I havent been able to have Arlo working in HA. The login works fine when testing it from a browser.
2020-04-02 15:32:17 ERROR (MainThread) [homeassistant.setup] Setup failed for arlo: Integration failed to initialize.
2020-04-02 15:32:17 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform arlo.alarm_control_panel: Unable to set up component.
2020-04-02 15:32:17 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform arlo.camera: Unable to set up component.
I had the same issue described above, where the official integration for Arlo stopped working, (incidentally checked the 2FA solution suggested, however that didn’t solve the problem for me…). I installed this custom component and so far so good. My installation is with 2pcs Arlo Q cameras.
The easiest way is to install the custom component is via HA HACS (Home assistant community store). The description of the custom component is excellent the developer did and outstanding job.
