Issue with Automatic Transaction Import via GoCardless in Firefly III
Hi everyone!
I’m trying to set up automatic transaction imports via GoCardless, but I feel like I might be missing a step or configuration detail. Could you please help me figure out what might be going wrong here?
Here’s what I’ve done so far:
1. I’m running Home Assistant OS, and I’ve installed the Firefly III and Firefly III Data Importer add-ons.
2. I configured Firefly III and linked it to Firefly III Data Importer.
3. I registered on GoCardless and added the ID and KEY to the Firefly III Data Importer configuration. I also enabled the CAN_POST_AUTOIMPORT and (not sure if necessary) CAN_POST_FILES options. Additionally, I set the update frequency to hourly.
4. I performed a manual sync with my bank, and everything works fine when done manually. I also downloaded the configuration file and placed it in the /addon_configs/xxx-fireflyiii_data_importer/import_files folder.
After that, when I start the Firefly III Data Importer add-on, the logs show the following entry:
“Automatic updates were requested. The files in /config/import_files will be imported hourly.”
And that’s it—nothing happens after that, no hourly updates, not even daily ones. No matter how long I wait, the process doesn’t seem to run.
What could I be missing here?
I’m not familiar with this addon, by thanks for opening my eyes to it. Just an observation, but shouldn’t CONFIG_LOCATION* be set to /config/addon_configs/ (or possibly just /addon_configs/) since that’s where you put it?
I haven’t changed this option; it’s set as default in the addon. The documentation doesn’t really say much about it either. Honestly, I don’t think this is the issue.
But thanks! I’ll try testing a few different options here anyway. :slight_smile:
Facing the exact same issue as well. Not sure what else needs to be configured.
I also setup the 16 characters password in the importer addon config options that appears after enabling auto post options.
Did you manage to make it work?
Yes, the import is working for me now. I don’t know what I did, I just logged into my bank a few times, exported the file, and added it to the correct folder. Then I waited for a few hours again. At some point, it all started working…
Sorry for the off-topic question but, where are you hosting the firefly instance?
I am trying to get started but saw that the firefly addon is depreciated and no longer maintained.
Is there another way to host firefly on a HA machine?
Did you change the CONFIG_LOCATION?
Don’t know if it helps but im using proxmox LXC.
https://community-scripts.github.io/ProxmoxVE/scripts?id=firefly
And one more thing where did you get your acces token?
Did i do something wrong here?
Instructions:(https://docs.firefly-iii.org/how-to/firefly-iii/features/api/)
My settings:
