I get this error when my automations look like this
Logger: homeassistant.config
Source: config.py:464
First occurred: 6:57:13 AM (3 occurrences)
Last logged: 6:57:20 AM
Invalid config for [automation]: Service switch.turn_{{‘on’ if trigger.id = ‘on’ else ‘off’ }} target: entity_id: switch.fan_controller does not match format . for dictionary value @ data[‘action’][0][‘service’]. Got None. (See /config/configuration.yaml, line 3).
- id: '1638223769335'
alias: Fan Control
description: Tun off fan in the morning, on at bedtime
- platform: time
at: 06:30:00
- platform: time
at: '20:30:00'
condition: []
- service: "switch.turn_{{'on' if trigger.id = 'on' else 'off' }} target:\n entity_id:\
\ switch.fan_controller\n"
mode: single
and configuration looks like this
# Activate the configuration editor
config:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
#http:
#base_url: wadsley.duckdns.org:8123
# ssl_certificate: 78e65fad-9879-4d30-916e-f2ec94cd929c
# ssl_key: /ssl/privkey.pem
# Text to speech
#tts:
# - platform: google_translate
#group: !include groups.yaml
#automation: !include automations.yaml
#script: !include scripts.yaml
#scene: !include scenes.yaml
alias: Fan Control
- platform: time
at: 06:30:00
- platform: time
at: '20:30:00'
condition: []
- service: "switch.turn_{{ trigger.id }}"
mode: single
EDIT
Alternative:
alias: Fan Control
- platform: time
at:
- '06:30:00'
- '20:30:00'
condition: []
- service: "switch.turn_{{ 'on' if now().hour == 20 else 'off' }}"
mode: single
that’s wrong, your service line is missing the ending quote. Also, you can simplify this by removing the quotes because the field starts with a character and not {{. Lastly, just use the id field to select the service instead of the if statement.
alias: Fan Control
- platform: time
at: 06:30:00
- platform: time
at: '20:30:00'
condition: []
- service: switch.turn_{{ trigger.id }}
mode: single
Ya, to help visualize what I’m trying to do, the editor is really helpful. I often can’t figure out how the yaml is broken when something doesn’t work…
Occasionally toggle between the two editing modes to develop an understanding of how whatever you create in UI mode is constructed in YAML mode. Eventually you’ll be able to compose it directly in YAML (which allows you to do a few things that aren’t supported in UI mode).
FWIW, I don’t use the Automation Editor and prefer to compose automations using a text editor (Microsoft VS Code). The Automation Editor, in UI mode, is fine for creating simple automations but gets in one’s way when complexity increases. It also has a few limitations that, once you encounter them, serve to make you seek a more flexible means of composing automations.
