Issue with blueprint created from working automation
I have an issue where I’ve created a blueprint from a working automation. I then create a new automation from the blueprint. The newly created automation works perfectly on immediate testing. No issues, errors, nothing. However, as soon as I restart HA for any reason, HA won’t load automations.yaml and all automations cease to function. I have to remove the offending automation manually and reload HA before the automation UI will return to normal. I’ve gone round and round and round trying to figure out what is causing this in the blueprint, but I can’t find it. I use hubitat for zwave/zigbee devices and have lifx bulbs throughout the house. The goal is to get a working blueprint so I can quickly associate inovelli red series switches (in smart bulb mode) from hubitat with corresponding lifx bulbs.
Working automation:
alias: KitchenTableSwitchLifxBulbsSync
description: ""
  - device_id: c097e26e4b55e34a1a662d33bd3f7b2d
    domain: hubitat
    platform: device
    type: pushed
    subtype: "1"
    domain: hubitat
    platform: device
    type: pushed
    subtype: "8"
    domain: hubitat
    platform: device
    type: pushed
    subtype: "6"
    domain: hubitat
    platform: device
    type: held
    subtype: "8"
    domain: hubitat
    platform: device
    type: held
    subtype: "6"
    domain: hubitat
    platform: device
    type: held
    subtype: "1"
  - platform: device
    type: turned_on
    entity_id: light.kitchen_table_light
    domain: light
  - platform: device
    type: turned_off
    domain: light
  - platform: state
    entity_id:
      - light.kitchen_table_lifx_bulbs
    to: "on"
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: light.turn_on
              transition: 1
              brightness_pct: 100
              entity_id: light.kitchen_table_lifx_bulbs
      - conditions:
        sequence:
          - repeat:
              until:
                - condition: state
                  attribute: brightness
                  state: "100"
              sequence:
                    brightness_step_pct: "6"
                    transition: "{{ 100 / 1000 }}"
      - conditions:
        sequence:
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 100
      - conditions:
        sequence:
          - repeat:
              until:
                - condition: numeric_state
                  below: 1
              sequence:
                    brightness_step: "-12"
      - conditions:
        sequence:
          - delay:
              hours: 0
              minutes: 0
              seconds: 0
              milliseconds: 100
      - conditions:
        sequence:
          - service: light.turn_off
              transition: 1
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
          - type: turn_on
            domain: light
      - conditions:
        sequence:
          - type: turn_off
            domain: light
mode: restart
Blueprint:
blueprint:
  description: Allows a red series dimmer to be synced with a lifx bulb or bulb group to enable on/off, hold to dim, and mirror state between lights and switch.
  domain: automation
  input:
    red_dimmer:
      name: Red Series Dimmer
      description: Red Series Dimmer to associate.
      selector:
        device:
          model: Inovelli Dimmer Red Series LZW31-SN
          multiple: false
    light_entity:
      description: Light entity to control.
      selector:
        entity:
          domain: light
          multiple: false
    transition_on:
      name: On Transition
      description: The duration in seconds for the light entity to transiton on.
      default: 1
      selector:
        number:
          min: 0.0
          max: 15.0
          unit_of_measurement: seconds
          step: 1.0
          mode: slider
    transition_off:
      name: Off Transition
      description: The duration in seconds for the light entity to transiton off.
      default: 1
      selector:
        number:
          min: 0.0
          max: 15.0
          step: 1.0
          mode: slider
    step:
      name: Brightness Step Percentage
      description: The percentage of brightness to which the light is changed when
        the RAISE/LOWER button is pressed and held.
      default: 10
      selector:
        number:
          min: 1.0
          max: 25.0
          unit_of_measurement: percentage
          step: 1.0
          mode: slider
    speed:
      name: Brightness Transition Speed
      description: The rate in milliseconds at which the brightness of the light entity
        will be changed.
      default: 250
      selector:
        number:
          min: 100.0
          max: 2000.0
          unit_of_measurement: milliseconds
          step: 1.0
          mode: slider
variables:
  step: !input step
  speed: !input speed
  - device_id: !input red_dimmer
    domain: hubitat
    platform: device
    type: pushed
    subtype: "1"
    domain: hubitat
    platform: device
    type: pushed
    subtype: "8"
    domain: hubitat
    platform: device
    type: pushed
    subtype: "6"
    domain: hubitat
    platform: device
    type: held
    subtype: "8"
    domain: hubitat
    platform: device
    type: held
    subtype: "6"
    domain: hubitat
    platform: device
    type: held
    subtype: "1"
  - platform: device
    type: turned_on
    entity_id: !input light_entity
    domain: light
  - platform: device
    type: turned_off
    domain: light
  - platform: state
    entity_id:
    to: "on"
  - platform: state
    entity_id:
    to: "off"
condition: []
  - choose:
      - conditions:
        sequence:
              transition: !input transition_on
              brightness_pct: 100
      - conditions:
        sequence:
          - repeat:
              until:
                - condition: state
                  state: "100"
              sequence:
                    brightness_step_pct: !input step
                    transition: "{{ speed / 1000 }}"
      - conditions:
        sequence:
          - delay:
              milliseconds: 100
      - conditions:
        sequence:
          - repeat:
              until:
                  below: 1
              sequence:
                    brightness_step: '{{ step * -2 }}'
      - conditions:
        sequence:
          - delay:
              milliseconds: 100
      - conditions:
        sequence:
              transition: !input transition_off
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
            data: {}
      - conditions:
        sequence:
          - type: turn_on
            domain: light
      - conditions:
        sequence:
          - type: turn_off
            domain: light
mode: restart
Logs:
This error originated from a custom integration.
Logger: homeassistant.setup
Source: custom_components/hubitat/hub.py:471
Integration: Hubitat (documentation, issues)
First occurred: 8:59:20 PM (1 occurrences)
Last logged: 8:59:20 PM
Error during setup of component automation
  File "/usr/src/homeassistant/homeassistant/setup.py", line 235, in _async_setup_component
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 238, in async_setup
    if not await _async_process_config(hass, config, component):
  File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 671, in _async_process_config
    await async_validate_config_item(hass, raw_config),
  File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 74, in async_validate_config_item
    config[CONF_TRIGGER] = await async_validate_trigger_config(
  File "/usr/src/homeassistant/homeassistant/helpers/trigger.py", line 94, in async_validate_trigger_config
    conf = await platform.async_validate_trigger_config(hass, conf)
  File "/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py", line 66, in async_validate_trigger_config
    return await platform.async_validate_trigger_config(hass, config)
  File "/config/custom_components/hubitat/device_trigger.py", line 90, in async_validate_trigger_config
    hubitat_device, _ = get_hubitat_device(hass, device.id)
  File "/config/custom_components/hubitat/device_trigger.py", line 213, in get_hubitat_device
    hub = get_hub(hass, entry_id)
  File "/config/custom_components/hubitat/hub.py", line 471, in get_hub
    return hass.data[DOMAIN][config_entry_id]
KeyError: '1750592be759a02405c6157b9c2c6bd1'
