Hi all, really need help with getting a command line switch to work, the code I’ve got from the forum is probably a couple years old and my best guess is it’s depreciated ?
Basically the switch won’t even show on my HA instance which I’d expect should be at “switch.aquariumledmanual”
The syntax is the same regardless of what file you use. Important thing is that your configuration.yaml file is properly referencing your file, and the yaml syntax is correct. Your original layout is not correct.
