Why didn’t you say so earlier. By the way your picture proves nothing, I can’t see the complete payh.
By the way, you haven’t got zha and z2m active at the same time do you?
the Path on that picture is complete… if u read it carefully.
no z2m is stopped,
2022-05-26 12:27:55 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Sonoff Zigbee 3.0 USB Dong - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22ce4be9743bec119ea0a4957a0af07f-if00-port0, s/n: 22ce4be9743bec119ea0a4957a0af07f - ITead - 10C4:EA60' for zha integration not ready yet; Retrying in background
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x3522:1:0x0702]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x3522:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x3522:1:0x0b04]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCD5D:1:0x0b04]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCD5D:1:0x0702]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
2022-05-26 12:28:53 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0xCD5D:1:0x0006]: async_initialize: all attempts have failed: [DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>'), DeliveryError('Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>')]
In the first pic (please don’t post pics of text by the way) but you can’t tie that into the second picture of the ui.
its correct: thats from zha UI>
its constantly failing
Zigbee2MQTT:error 2022-05-26 12:35:43: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:102:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:123:29)
at Zigbee.start (/app/lib/zigbee.ts:58:27)
at Controller.start (/app/lib/controller.ts:100:27)
at start (/app/index.js:110:5)
Well its a mystery. Perhaps try reflashing the stick, maybe the firmware is corrupted?
I assume you have unplugged / replugged the stick, cold rebooted the computer?
Perhaps broken?
This is ZHA. If you have both ZHA and Zigbee2mqtt installed, both will fail.
@was reflashed few minutes ago nothing,
yes
rebooted
broken? Its brand new stick worked till todays morning .
no, ZHA is working - or at least shows it works.
log
Zigbee2MQTT:debug 2022-05-26 12:41:23: Removing old log directory '/config/zigbee2mqtt/log/2022-05-26.12-36-21'
Zigbee2MQTT:info 2022-05-26 12:41:23: Starting Zigbee2MQTT version 1.25.1 (commit #unknown)
Zigbee2MQTT:info 2022-05-26 12:41:23: Starting zigbee-herdsman (0.14.27)
Zigbee2MQTT:debug 2022-05-26 12:41:23: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/config/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","databasePath":"/config/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_22ce4be9743bec119ea0a4957a0af07f-if00-port0"}}'
Zigbee2MQTT:error 2022-05-26 12:41:50: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-05-26 12:41:50: Failed to start zigbee
Zigbee2MQTT:error 2022-05-26 12:41:50: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-05-26 12:41:50: Exiting...
Zigbee2MQTT:error 2022-05-26 12:41:50: Error: SRSP - SYS - getExtAddr after 6000ms
at Timeout._onTimeout (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (internal/timers.js:557:17)
at processTimers (internal/timers.js:500:7)
[12:41:52] INFO: Handing over control to Zigbee2mqtt Core ...
so it looking for some coordinator_backup files which are not there
[core-ssh zigbee2mqtt]$ ls -al
total 20
drwxr-xr-x 3 root root 4096 May 26 12:40 .
drwxr-xr-x 10 root root 4096 May 26 12:30 …
-rw-r–r-- 1 root root 301 May 26 12:40 configuration.yaml
drwxr-xr-x 13 root root 4096 May 26 12:43 log
-rw-r–r-- 1 root root 2 May 26 12:41 state.json
i would say… crap code, crap hardware.
I suspect you only have one stick. You can use ZHA or Zigbee2mqtt, but not both at the same time using the same stick. If ZHA is working, Zigbee2mqtt will never work.
No its not,
@francips then its my idiocity, sorry - bc i firstly executed ZHA - and then i tried to start zigbee2mqtt… no idea why.
@francips
so i disabled it ; rebooted
restarted zigbee2mqtt
error is now different
Zigbee2MQTT:error 2022-05-26 12:55:24: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2022-05-26 12:55:24: Failed to start zigbee
Zigbee2MQTT:error 2022-05-26 12:55:24: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2022-05-26 12:55:24: Exiting...
Zigbee2MQTT:error 2022-05-26 12:55:25: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby
at ZnpAdapterManager.beginCommissioning (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:347:23)
at ZnpAdapterManager.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:92:17)
is it possible to "If you still get this error after increasing the panID "?
i have 3 devices which were previously paired with that stick, even i reflashed the stick.
ok i did something else:
i restored zigbee2mtq old configuration folder with state.json and coordinator_backup.json
and its booted up; or at least seems to work.
ok not maybe working … when i execute scan of the network most of the devices are returning
error 2022-05-26 13:12:30Failed to execute LQI for
You will need to re-pair them.
@francisp once u reflash the coordinator firmware the configuration is loaded into the stick from zigbee2mqtt files, right?
by repair u mean remove it from UI and add it again?
