Issue with coordinator
Simply pressing the pairing button should do the trick.
seems work, but have one more device
sonoff usb3.0 as router
error 2022-05-26 13:43:41Failed to execute LQI for 'sonoff-router'
but i cant press button on it … ;/
well i refleshed it again and it got re-linked… ehm
but still network map shows 2 devices unlinked
even devices section shows
well i see zigbee is not good way to go … zwave seems fix issue with all that nonsense.
then i did movement - and sensor got linked inside the map view… well …
Exactly. Two applications cannot use the same serial port.
ok, thanks solved.
