I have a problem using the cover slider on the Mushroom cover card. For most covers using the slider just leads to nothing…the covers dont move and I dont know why. For just 2 Windows in our House the slider works as intended.
I really don’t know what the reason for this could be. Does it have something to do with the card or with the KNX installation/Integration?
Many thanks in advance for your help/ideas
have you compared the entity’s in developer tools. compare state/attributes to one that works and one that doesn’t.
Hey, i have compared the yaml Code. Its all the same with the different group adresses. Is that what you mean?
Buttons etc are working. Its Just the sliders that dont.
I don’t have covers but I would imagine the set_cover_position isn’t being exposed so it doesn’t know the position for the slider.
![ef3149ebfafa2506573001f69a38e14b142fe522](https://community-assets.home-assistant.io/original/4X/3/9/5/395e09154a6ddc3a2fe847c4f627103a4f4f1d92.png)
do you have a position in the entity details tab, or is it greyed out?
I dont know what to do in developer tools. It doesnt look similar, maybe because i use mushroom card mod? But Everywhere where I compare the attributes, they are realy all the same…weird…
Update:
If you look at the history, everything looks quite normal. When I press the slider, Home Assistant also thinks that the shutter has moved. However, it does not move. As I said… it works with some shutters and not with others. I couldn’t find any differences in the ETS itself.
