I am experiencing an issue with custom components updating core version to a newer then 2021.5.5.
I have Homeassistant installed on a Raspberry using 2 custom components (correctly working on 2021.5.5):
- Smart IR
- Variable
When I update to newer version that 2021.5.5 (eg. 2021.8.8) I got an issue because these components are not loaded getting the following error messages on a log:
Platform error: climate - Integration 'smartir' not found.
22:50:24 – (ERRORE) config.py - il messaggio si è verificato per la prima volta alle 22:50:23 e compare 2 volte
Setup failed for variable: Integration not found.
22:50:23 – (ERRORE) setup.py
Did I lost some important breaking changes? Someone is it experiencing the same error? Any help is great!
Alessandro
