Issue with Device Tracker iOS app not updating? (always home or away)
Exactly the same for me. I also have a new _2 and the location is not updating. My wife has no _2 but her location is also not updating. Both stopped to work at the same time (3 days ago)
The same for me. The location has not been updating for two or three weeks. I know Android users who have the same problem.
the same problem, also the charging state not update, removing one device and re add it will fix it, but another iOS phone get the same problem, so what is happening can anyone explain reopening the app will update all the states but after while return to the same problem
I had the same issue with my wife’s phone. I resolved it by now having both the Apple Icloud and Icloud3 Integrations and noticed that the issue was my wife’s Iphone entity in Icloud3. I deleted that device in Icloud3 and kept it in Apple Icloud. That did the job.
Same issue here. Is there a fix at the next time?
Greets
I believe I have figured out the _2 thing as it happened to me and my iphone 10 was not updating its geo code location.
I was using my iphone as a personal hotspot when I was away and I believe what happened is that when I turned on the personal hotspot, it connected to the cell provider in the area. The HA mobile app on my iphone then communicated with HA and set that geo location. I noticed that after the recent HA core update, that MAPS was moved in my sidebar. I clicked on it and noted my iphone was still showing as where I was weeks earlier and that there were two iphones showing and one with an _2. I Tried to delete the duplicate which it did but that did not solve my problem.
To make a long story short, I finally noticed that I had left my personal hotspot setting to ON on my iphone. I turned the personal hotspot off and almost instantly my location updated to where I was ( home ).
So, if you see an _2 iphone device added and you had been using a personal hotspot and forgot to disable your personal hotspot (left it as “on” under settings/personal hotspot) try disabling the personal hotspot and see if your location starts updating again.
My theory is that the personal hotspot setting must be interfering with the location setting within the HA mobile app.
I know that when I do travel that I turn on my personal hotspot so that everyone in the car can surf while we are driving somewhere. I often forget to turn it off when we arrive or when I get back home.
Let’s see if anyone can confirm this!
Same here, but it started on my new iPhone. I went from an 11 to 14. On my iPhone 11 the zone detecting worked very good, in some seconds I got a notificaion I left or came home. Not with my iPhone 14, when leaving I got the notification directly, but when coming home, it takes hours before it get updated. I saw in the log, that indeed the location was updated hours later. And even maybe by using the app, not sure. Settings are the same as on my 11, very frustrating.
I don‘t use nabus cloud service, our phones are set to always but it doesn‘t work. The workaround I use is to track if the phones are connected to WiFi, but that disables some features, like distance etc.
for those ios with location tracking issue, this was my solution:
ios i just got it not working to working:
HA settings > device > mobile device > deleted all of false registered mobile devices and even current one > close app(probably forced logout) > make sure ios settings home assistant app location setting as always allow > open home assistant app > login > go to setting > companion app > you home assistant name > privacy settings to be location sent exact, sensors sent all > go back one menu > “location” > update location > check device location entity get updated
The key step was to force delete all of false registered current device. Basically deleted current mobile from HA instead simple logout
Kind of late to the party :slight_smile: but my wife’s mobile has stopped updating her location out of the blue. I’ve tried all of the remove/recreate/logout/delete options and even deleting and reinstalling the app but nothing seems to work. I have even rebooted the HA in between steps. Not sure what else to do/check. The device always it’s “home” in the Home Zone. My device works just fine. Ideas?
