Hi everyone, I’m facing an issue with some entities in Home Assistant. The data for these entities appears in the history, but it shows in a darker color than usual, indicating that the data exists but is “hidden” or not fully accessible. Here are the details:
The entities are functioning correctly, and the data is present in the history.
I’ve noticed that the data appears in a darker tone, but I can’t access it as I normally would.
When I add a card with a temperature graph, the data for the month shows as if recording started on a specific day. However, when I open the history of any entity, I can see the previous data, but it appears darker, as if it’s not fully available.
Has anyone faced this issue or has suggestions on how I can solve it? Any help is greatly appreciated.
A screenshot may help you explain what you’re seeing. If you’re asking about the history panel, it does show data in a different color when pulling from Long Term Statistics vs regular state history, but I can’t tell if that’s what you’re seeing or not.
El problema que tengo es que voy a crear una gráfica por ejemplo de estas temperaturas y solo me deja ver desde el 28 de agosto, nunca más atrás como si no hubiese más datos.m, pero el historial muestra d que si no hay pero se otro color…/.gracias por su ayuda
The lighter data on the left is from the long term statistics.
The darker data on the right is from your recorder, which by default keeps data for the past 10 days.
Please post in English so that we can help answer your question. From what little Spanish I know, you want to show more than 10 days data in your card, right?
