Hi All, I started getting the following error message on my ESP32 devices in the log on ESPHome.
WARNING Disconnected from API: Timeout while waiting for message response!
INFO Connecting to 192.168.xx.125:6053 (192.168.xx.125)
I noticed that in the logbook my entities we going to unavailable the would restore to their correct state and then unavailable again 20sec after the reconnection.
I have tried taking my code back to a basic setting to try remove the problem but it still exists with a minimal yaml.
substitutions:
room: "control"
loc: "panel"
upper_room: "Control"
upper_loc: "Panel"
terminal01: "front_porch_pir"
terminal02: "bedroom1_pir"
terminal03: "hallway2_pir"
terminal04: "backroom_pir"
terminal05: ""
terminal06: ""
terminal07: ""
terminal08: ""
terminal09: ""
terminal10: "lounge1_pir"
terminal11: "hallway1_pir"
terminal12: "relay_1"
terminal13: "relay_2"
terminal14: "alarm_siren"
terminal15: "alarm_strobe"
esphome:
platform: ESP32
board: nodemcu-32s
wifi:
ssid: "abcdefghij"
password: "0123456789"
# # Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "Control Panel Fallback Hotspot"
# password: "0123456789"
manual_ip:
static_ip: 192.168.xx.125
gateway: 192.168.xx.1
subnet: 255.255.255.0
fast_connect: true
# #captive_portal:
# # Enable logging
logger:
level: VERBOSE
# # Enable Home Assistant API
api:
ota:
any suggestions on how i can fix it?
It seemed to start last night for no apparent reason and when it drops out from home assistant it does not appear to drop off my wifi.
Thanks heaps for any assistance.
Ben
