Issue with finding USB ports
Hi
i am having an issue adding a MySensors serial gateway not able to find port id
i am running the following
UDOObuntu 2 on a UDOO-QUAD
home-assistant is installed in Virtualenv
home-assistant is running fine and has located two wemo switches but i would like to add a motion sensor which is running on mysensor system, is it something to do with the ENV it is running in
chilliman1
Hi!
Can you post the mysensors part of your home assistant config? Do you see anything related to mysensors in the hass log after start?
