Hi all,
I am new to ESPHome and to soldering in general. I was trying to follow this guide to create a NFC tag reader: https://github.com/adonno/tagreader. I soldered all the connections per the diagram:
When I tried to flash my ESP8266 via ESPHome addon in Home Assistant, I get the following error:
I tried to also flash it with the ESPHome Flasher and I get this error:
I tried to look up multiple solutions and tried different things like different USB ports, different USB cables, running the flasher as an administrator, holding the reset button down while flashing but I continue to get the same errors.
The interesting thing is when I remove all the soldered connections and just plug only the ESP8266 in, I am able to flash it through Home Assistant and the ESPHome Flasher but I don’t see it appear as a device in Home Assistant.
Successful flashing of the ESP8266 with all soldered connections removed
Successful flashing through ESPHome addon in Home Assistant
Any help/suggestions would be very much appreciated. Thank you.
