Issue with HAOS installation on x86 platform
hi, sorry for asking immediately for support but I’m struggling with 1 day with an issue during installation process for HAOS on a X86 PC. I follow the procedure and after image installation via Ubunt restoring image, I launch the final update and installation process and from web console I see this recurring message:
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.11.1: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.11.1/json: Not Found (“No such image: ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.11.1”)
I checked internet connectivty and it is ok, I would understand if I can install this packages from command line in case or how I should fix it.
I already tried to start from scratch with procedure of installation and it is the same.
Francesco
