Hi Team, i have a strange issue and hope you can help me out
I created about 25+ helpers over the Dashboard so Settings > Devices > Helpers
All Helpers are “Number” and after i created i found out all are using Mode: Sliders instead Text
So i wanted to do following
- rename all with another friendlyname
- change mode to text
both is only manual possible as i understood right
Issue i now have, i can’t delete the helpers in Dashboard
so as you see on the Screenshots their is no option to change something or to delete,
so how i manually can remove them?
fyi, i dont unse configuration yaml or similar for the helpers as now
