Hi everyone,
I am experiencing problems with my Home Assistant Green after trying to install DuckDNS. Here is what happened:
- Initial Context
- I tried to install DuckDNS to enable external access but did not complete the setup.
- Right after that, the device stopped working, and I have not been able to access Home Assistant since.
- Steps I have Taken to Solve the Problem
Reinstalled the Operating System:
- Downloaded the official Home Assistant OS image from the official website.
- Used Balena Etcher to flash the image onto a new SD card (class 10, good quality).
- Inserted the SD card into the device and powered it on.
Current Device Status:
- The lights on the Home Assistant Green are as follows:
- White light is solid.
- Yellow and green lights are blinking constantly.
- It seems the boot process is not completing.
Network Connection:
- The device appears in my router with the IP 192.168.0.17.
- I cannot access it via a browser (http://192.168.0.17:8123).
- When I ping the IP, the result is:
- Host is down or No route to host.
Other Actions Taken:
- Changed the Ethernet cable and tried a different port on the router.
- Restarted both the router and the Home Assistant Green several times.
- Questions
- Could DuckDNS have left any persistent files or configurations that were not removed during the OS reinstallation?
- What else can I try to resolve this issue?
I currently do not have access to a monitor or keyboard to connect to the device, but I could try that if needed.
- Environment
What version of Home Assistant Core has the issue?
I am not sure, as I cannot access the system.
What was the last working version of Home Assistant Core?
I do not recall the exact version, but it was the latest version available when I installed DuckDNS.
What type of installation are you running?
Home Assistant OS.
Anything in the logs that might be useful?
I cannot access the logs because the system will not boot properly.
Additional Information
Any help or suggestions would be greatly appreciated. Thanks in advance for your support.
