Issue with ILI9488 when using LVGL
I’m new to Home Assistant and ESPHome so, please, be patient with me.
I’m trying to connect a ILI9488 display (Amazon.com: Fafeicy LCD Module, TFT Touch Screen Display Serial Peripheral Interface ILI9488 HD 480x320 3.5in (1 PCS) : Industrial & Scientific) to and ESP32-S3-DevKitc-1 N16R8.
When i try the show_test_card = true i correctly have the test image, but when i try to use LVGL I have these strange results
I’ve tried reading other post but with no luck.
Does anyone have an idea of what the problem could be?
Here is my config file which can be definitely optimized:
esphome:
  friendly_name: ESP32-S3-TFT-Test
  platformio_options:
    build_flags: "-DBOARD_HAS_PSRAM"
    board_build.arduino.memory_type: qio_opi
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
    - delay: 500ms
    - light.turn_off: led_strip
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
  flash_size: 16MB
psram:
  mode: octal # Please change this to quad for N8R2 and octal for N16R8
  speed: 80MHz
# Enable Home Assistant API
api:
  encryption:
    key: "******************************"
  on_client_connected:
    then:
      - delay: 50ms
# Enable logging
logger:
  level: VERBOSE
  logs:
    ili9xxx: VERBOSE
ota:
  - platform: esphome
    password: "****************************"
wifi:
  ssid: !secret wifi_ssid
  reboot_timeout: 15min
  ap:
    ssid: "Esp32-S3"
    password: ""
  power_save_mode: none
  enable_on_boot: True
  fast_connect: On
  output_power: 8.5
captive_portal:
# Define a PWM output on the ESP32
output:
  - platform: ledc
    pin: GPIO47
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO09
    num_leds: 29
    rmt_channel: 1
    chipset: ws2812
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
      - addressable_scan:
          name: "Scan Effect With Custom Values"
          move_interval: 5ms
          scan_width: 10
  - platform: monochromatic
    output: backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
#SPI Configuration for Display
spi:
  clk_pin: GPIO17 # SCK
  mosi_pin: GPIO21 #SDA (SDI-MOSI)
display:
  - platform: ili9xxx
    model: ili9488
    dc_pin: GPIO16
    reset_pin: GPIO48
    cs_pin: GPIO5
    invert_colors: true
    auto_clear_enabled: false
    update_interval: never
    rotation: 270
    dimensions:
      height: 320
      width: 480
      offset_height: 0
      offset_width: 0
    data_rate: 40MHz
lvgl:
