Strange issue I found after some recent update (do not recall which one it was, I assume after implementation of global number formatting in users settings). It is related to entities card displaying input_number entities. Previously if the number was integer, it was displayed without decimals. Now at least one decimal is always displayed, which I do not want. Here is the card code:
I used here small trick configuring input_number.watering_start_time (Start Time) as having :00 as measurement unit, so the value of 3 was displayed as 3:00. After recent change and addition of always displayed decimal part it is displayed as 3,0:00, which does not makes sense as time formatting
I tried to use format option for individual entities in card, but it seems to be limited to only formatting timestamps.
Any idea how to remove decimal part? Or how to get this displayed properly? BTW, same applies (but not so much disturbing) to Days between watering cycles (2,0 days) and Cycle Duration (15,0 min)…
I think input_number has had the decimal for some time. When counter was introduced (last year?) I switched to that to get rid of it - would that help here?
Well, not really… indeed, I tested counter and it displays properly, but then I’d need to use some template to display its value formatted as time. It is also only controllable via services, so it is not possible to use slider to easily set its value. Of course soem combination of input_number to enter data and counter to just display value are possible, but this would overcomplicate solution over outcome. I’ll keep thinking about other ideas to get this to my liking and perhaps made it simple.
