Issue with install HAOS on VBOX VM
I’m new to HA and I am trying to install the HAOS on a vm per the instructions on the website. I have done the vm configuration 3 times and checked DNS settings everywhere that I can think of. I have also tried do this on windows and Linux.
I issue I continously run into is this in the install script :
2024-12-28 13:28:55.972 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-12-28 13:33:21.949 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.12.5: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.12.5&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.12.5": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fqemux86-64-homeassistant%3Apull&service=ghcr.io": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
2024-12-28 13:33:21.949 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
My first thought is a dns issue, but I have tried setting my dns to 8.8.8.8 everywhere and the same result. If there is someone out there who has recently set up HAOS on a vm successfully, Is there something you did differently from the instructions.
The process takes about 5 mins to set up for anyone who is familiar with virtual box.
Thanks in advance
Also, i’ve others with the same issue on reddit, but no solution yet.
Try my guide (Proxmox based) and adapt to whatever virtualisation platform you are using.
https://portal.habitats.tech/Home+Assistant+(HA)/3.+HAOS+-+Install+VM
Fixed my Issue:
I switch my setting on my router back to “get DNS automatically from ISP”. Boom! Were in business!
