Issue with Lagrand Integration
Hello
I have some light and shutter switches from Legrand in use. The integration is done by Netatmo.
My switches behave a bit strange. When I turn on a light after about a second the switch in Home Assistant falls back to status off but in reality light is on. After a while some minutes the status in the dashboard changes then also to on.
So in generally it works but the status update is much to slow in my opinion. Does someone of you knows this problem or knows how to fix this? Would really appreciate a reply.
BR
