I added my light bulbs from Tuya home, and they imported as being only RGB bulbs, and not having the option to select the white temp., but I can select the white temp. in the tuya app. How can I fix this?
This has already been reported as a bug.
opened 09:41PM - 06 Apr 24 UTC
### The problem
Since HA 2024.4.0 I noticed that HA does not show the co… lor mode correctly of my Tuya bulbs.
So
- on/off is correctly displayed
- when I change color in HA: icon shows the selected color
- when I switch back to white modus in the Tuya app (I can’t switch to white modus in HA): the color of the icon in HA remains in color modus although the bulb works now in white modus
- on/off works in HA, but when I want to change the brightness in HA, the old color modus is sent to the bulb
This makes that all my Tuya bulbs become more or less useless in HA:
- I can’t switch to white modus in HA
- I can’t dimm my lights because than they switch to a random color modus
Anybody same problem?
Any solution?
Kind regards,
Bart Plessers
### What version of Home Assistant Core has the issue?
core-2024.4.1
### What was the last working version of Home Assistant Core?
core-2024.3.x
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Tuya
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/tuya/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
Is the repository actively being updated? I noticed a lot of open bugs in the issues.
I mean, it’s HA core, so it is definitely being updated. But the Tuya integration is a collaboration between Tuya and HA, so I don’t know the frequency that those particular bugs are being worked on.
