Issue with Modbus serial RTU when using Rpi5 /Rpi500
Hello
I am quite new to the HA environment; however, I do have a good background in C/C++ .
I have an Rpi500 with a USB to RS485 dongle connected to two Modbus thermostats. Hardware is all tested separately and is working.
When I write my code in the configuration.yaml, everything works fine
configuration.yaml
Loads the default set of integrations. Do not remove.
default_config:
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
modbus:
  • name: RS485_hub
    type: serial
    baudrate: 38400
    bytesize: 8
    method: rtu
    parity: E
    port: /dev/ttyUSB0
    stopbits: 1
    timeout: 1
    sensors:
    • name: TT1000_1_addr
      slave: 170
      address: 0
      scan_interval: 10
    • name: TT1000_1_SP
      slave: 170
      address: 7
      scan_interval: 10
    • name: TT1000_1_FS
      slave: 170
      address: 8
      scan_interval: 10
    • name: TT1000_2_addr
      slave: 171
      address: 0
      scan_interval: 1
The code loads properly, and the data is read and displayed on the frontend
However, I would like to separate the serial initialisation and the Modbus registers declaration.
I am trying to do as follows:
configuration.yaml
default_config:
frontend:
modbus: !include Modbus_serial/modbusRTU.yaml
sensor: !include Modbus_serial/ThermostatsTT1000.yaml
Filename: modbusRTU.yaml
Author: Joseph Agius
Email: [email protected]
Created: 02/07/2025
Edited last: 03/07/2025 08:00am
Description: Serial connection code via RS485 for Modbus RTU data
Modbus RTU connection
  • name: RS485_hub
    type: serial
    baudrate: 38400
    bytesize: 8
    method: rtu
    parity: E
    port: /dev/ttyUSB0
    stopbits: 1
    timeout: 1
##################### END OF CODE ########################################
Filename: ThermostatsTT1000.yaml
Created: 02/07/2025
Description: Declaration of sensors - starting with TT1000 thermostats
TT1000 by Thermostat declaration
  • platform: modbus
    scan_interval: 10
    registers:
      hub: RS485_hub
      slave: 170
      register: 0
      register_type: holding
##################### END OF CODE #########################################
Can anyone guide me and maybe point out what I am doing incorrectly?
Is there a debugger that I can use on the RPI500 directly?
Errors
Thanks in advance
JA
