Thank you Farmio,
For some reason the hardest part for me was finding the log files back. since the system is already up for a long term I forgot how easy it was to find them back!
The root cause seems to be a disconnect on the KNX tunneling device, why this happens i’m not sure yet but I can see from the timestamps that HA is able to reconnect immediatly. This reconnection reads out the NC states of the magnetic contacts causing to trigger the automation.
Thanks a lot Farmio and tom_l for such a quick solution to this annoying problem.
Now I can literally again sleep better at night ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
I give an update in a couple of months anyway
Greetings
Stijn
2022-08-18 00:55:04.625 WARNING (KNX Interface) [xknx.log] Received DisconnectRequest from tunnelling sever.
2022-08-18 00:55:04.655 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('ValueError: Template error: float got invalid input 'unavailable' when rendering template '{{ (states('sensor.water')|float * 1000) | round(0) }}' but no default was specified') while processing template 'Template("{{ (states('sensor.water')|float * 1000) | round(0) }}")' for attribute '_attr_native_value' in entity 'sensor.water_consumption_l'
2022-08-18 00:55:04.662 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('ValueError: Template error: float got invalid input 'unavailable' when rendering template '{{ (states('sensor.waterarcus')|float / 1000 + 16.402) | round(0) }}' but no default was specified') while processing template 'Template("{{ (states('sensor.waterarcus')|float / 1000 + 16.402) | round(0) }}")' for attribute '_attr_native_value' in entity 'sensor.water_consumption_m3'
2022-08-18 00:55:04.664 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError('ValueError: Template error: float got invalid input 'unavailable' when rendering template '{{ (states('sensor.elektriciteit')|float / 1000) | round(0) }}' but no default was specified') while processing template 'Template("{{ (states('sensor.elektriciteit')|float / 1000) | round(0) }}")' for attribute '_attr_native_value' in entity 'sensor.electricity_consumption_kwh'
2022-08-18 00:55:10.692 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.004 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.008 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.020 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.028 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.034 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.078 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.293 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 4/6/23
2022-08-18 00:55:11.294 WARNING (MainThread) [xknx.log] Could not sync group address '4/6/23' (Water - Value)
2022-08-18 00:55:11.547 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.790 WARNING (MainThread) [xknx.log] Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 4/6/50
2022-08-18 00:55:11.792 WARNING (MainThread) [xknx.log] Could not sync group address '4/6/50' (gasmeter - Value)
2022-08-18 00:55:11.793 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.851 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.882 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.892 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.914 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.940 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found. This message is generated externally to Home Assistant.
2022-08-18 00:55:11.949 ERROR (MainThread) [homeassistant.components.automation.security_notify_alarm_triggered] [security] [triggered] notify: Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['colour']
2022-08-18 00:55:11.953 ERROR (MainThread) [homeassistant.components.automation.security_notify_alarm_triggered] Error while executing automation automation.security_notify_alarm_triggered: extra keys not allowed @ data['colour']
2022-08-18 00:55:11.968 ERROR (MainThread) [homeassistant.components.automation.security_night_alarm_activated] [security] [triggered] night alarm action: Error executing script. Invalid data for call_service at pos 2: extra keys not allowed @ data['colour']
2022-08-18 00:55:11.971 ERROR (MainThread) [homeassistant.components.automation.security_night_alarm_activated] Error while executing automation automation.security_night_alarm_activated: extra keys not allowed @ data['colour']
2022-08-18 00:55:12.202 ERROR (MainThread) [homeassistant.components.automation.security_mag_tuinhuis] [security] [mag] tuinhuis change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 447, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 680, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1713, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1750, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 676, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 930, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 713, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/alarm_control_panel/__init__.py", line 197, in async_alarm_trigger
await self.hass.async_add_executor_job(self.alarm_trigger, code)
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/manual/alarm_control_panel.py", line 350, in alarm_trigger
if not self._trigger_time_by_state[self._active_state]:
KeyError: 'triggered'
2022-08-18 00:55:12.212 ERROR (MainThread) [homeassistant.components.automation.security_mag_tuinhuis] While executing automation automation.security_mag_tuinhuis
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 521, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1513, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 405, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 449, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 472, in _handle_exception
raise exception
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.239 ERROR (MainThread) [homeassistant.components.automation.security_mag_garagepoort] [security] [mag] garagepoort change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.243 ERROR (MainThread) [homeassistant.components.automation.security_mag_achterdeur] [security] [mag] achterdeur change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.248 ERROR (MainThread) [homeassistant.components.automation.security_mag_atelier_straatdeur_change] [security] [mag] atelier straatdeur change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.252 ERROR (MainThread) [homeassistant.components.automation.security_mag_voordeur] [security] [mag] voordeur change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.258 ERROR (MainThread) [homeassistant.components.automation.security_mag_garagepoort] While executing automation automation.security_mag_garagepoort
raise exception
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.262 ERROR (MainThread) [homeassistant.components.automation.security_mag_achterdeur] While executing automation automation.security_mag_achterdeur
raise exception
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.263 ERROR (MainThread) [homeassistant.components.automation.security_mag_atelier_straatdeur_change] While executing automation automation.security_mag_atelier_straatdeur_change
raise exception
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.266 ERROR (MainThread) [homeassistant.components.automation.security_mag_voordeur] While executing automation automation.security_mag_voordeur
raise exception
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.287 ERROR (MainThread) [homeassistant.components.automation.security_mag_schuifraam] [security] [mag] schuifraam change: Error executing script. Unexpected error for call_service at pos 3: 'triggered'
await service_task
task.result()
await coro
await result
2022-08-18 00:55:12.290 ERROR (MainThread) [homeassistant.components.automation.security_mag_schuifraam] While executing automation automation.security_mag_schuifraam
raise exception
await service_task
task.result()
await coro
await result
