Issue with Netatmo config on 0.105.1
Hi
I have just upgraded to 0.105.1 and made changes to my configuration.yaml file as per instructions:
netatmo:
client_id: your_client_id
client_secret: your_client_secret
I have re-used the client_id and client_secret that worked before.
Now I am getting “entity not available: climate.netatmo_my_room” in the lovelace interface. I don’t have any errors in the home-assistant.log file.
In the release notes it says:
" If you have an existing configuration, you will need to remove/update that and run the configuration flow dialogue to get their sensors/etc, back using the configuration.yaml option."
What does that mean?
Dara
I think you must use the integrations page.
Thanks for your help. That worked for me. I hadn’t used that before.
