Hi there
I’ve created some “number” helpers (input_number) …
Now, I’ve noticed, that there’s no way to reconfigure them, nor to delete them!
The “Delete” option is missing in this dialog
using the cogwheel symbol in the top right cornor, there’s just an empty dialog.
Also, the three dots are only showing the option “related…” which does not show anything in my case:
So - for the sensor shown here, that’s not a big issue - I can use the “BOX” to change the value to whatever I want… (I think, up to the configured MAX)…
But - I cannot EDIT any parameters of the Helper, nor can I delete it to create a new one…
This will cause issues, when you need to adjust the max settings, for example - which can be the case.
Here, I’ve another input number which I need to increase for it’s max value.
Can someone pls. confirm if this is an issue that should be reported in github?
Or is this a considered and expected behave?
I would have guessed, at least - deleting the helper should be available…
