Issue with pem files from DuckDNS
The Netherlands, 27-09-2022
Hi all,
I have an issue with the .pem files. The files are created with the DuckDNS addon. I’m sure they are in the ssl directory because I can see them in the Windows file explorer witch I can use because of installing Samba share in HA.
When I add the http: section in de configuration.yaml:
http:
ssl_certificate: ‘/ssl/fullchain.pem’
ssl_key: ‘/ssl/privkey.pem’
I validate the yaml and it seams OK. Then I do a HA restart but HA will not start again.
Fortunately from Windows I can edit the HA configuration.yaml and so I can delete the http: section in the yaml file and then after a restart of my raspberry pi HA starts again.
Btw I can reach my HA over the internet (http) so DuckDNS works but its not over a secure line (https).
So HELP, what could be wrong?
Kind regards from the Netherlands
Arie-Jan
Use the nginx proxy to simplify.
