I have setup easyesp with a rotary encoder. The encoder is configured with a value from 1-100 with every ‘click’ making 4 steps. I have also tried setting it up with a value from 0-16 with 1 step per ‘click’ and translating that to a brightness value from 0-255, but that only improves it just a little, but is still pretty unusable.
I then use the state value of the rotary encoder entity to control a lights brightness_pct from 0-100.
If I view the entity of the encoder in hass, the value goes up and down very smoothly when rotating the encoder. So that works just fine.
As long as I use a single light, that all woks just fine and pretty smooth.
However when controlling the brightness of a hass light group OR a Philips Hue room/group of lights, this results in very unreliable dimming. The Hass light.turn_on > brightness_pct (or the brightness) command seems to have trouble catching up with the rotary encoder entity state value.
This is my configuration:
- platform: mqtt
state_topic: "/ESP_Easy/rotary1_dimmer/state"
name: "Livingroom 2 dimmer 1"
Automation:
- id: livingroom_2_dimmer_1
alias: "Livingroom 2 dimmer 1"
platform: mqtt
topic: /ESP_Easy/rotary1_dimmer/state
service: light.turn_on
entity_id: light.livingroom_group
data_template:
brightness_pct: '{{states.sensor.livingroom_2_dimmer_1.state}}'
Is there anybody who could point me to the solution for this issue?
