xmon-df
(Xmon df)
January 22, 2024, 1:27am
1
Hey folks,
I’m dealing with a quirky little issue. I have set up an LED as a “status_led” on my ESP32-S2 mini. When I have the log open, the LED is off, but when I close the log, it starts to blink. Judging by the blinking speed, it seems to be a WARNING rather than an ERROR.
ESPHome v 2023.12.6
I’ve tried changing the log level to NONE and DEBUG, but the behavior persists. Here’s my code:
logger:
level: NONE or DEBUG
output:
- platform: ledc
pin: GPIO3
light:
- platform: status_led
output: led_ota_wait
Additionally, if I check the log from my Linux terminal using the command:
screen /dev/ttyACM0 115200 | tee log.txt
I can see a line when closing the log in ESPHome:
[W][api.connection:104]: ESPHome Logs 2023.12.6 (192.168.1.77): Connection closed
Any bright minds out there have an idea why this might be happening?
Thanks for the help!
Hello and welcome.
Have you added it to Home Assistant as an integration yet?
@source_creator , I’m sorry to hear that you are having the same problem. At least I know I’m not alone.
I just built and programmed eight copies of a new board design, and one board of another design, programmed them up with ESPHome, and all nine were all blinking.
Then I saw the new device notification in the Home Assistant side bar, clicked “check it out” which took me to the integrations page, with all of my new nodes listed as newly discovered. I clicked on “…
xmon-df
(Xmon df)
January 22, 2024, 10:13am
3
No, I haven’t integrated it into Home Assistant yet. I’m working on the programming of the device and haven’t tackled Home Assistant yet.
Added, and goodbye to the Warning!! Thanks a lot, my friend.
guigui76
(Guigui76)
March 24, 2024, 8:12am
4
you can test this, it works for me
status_led:
pin:
number: GPIO15
inverted: True
#https://adafruit.github.io/Adafruit_WebSerial_ESPTool/
substitutions:
disp_name: s2-mini-bureau
#internal_name: led_bureau
internal_name: s2_mini_bureau
ip_address: !secret ip_S2_bureau
update_time: 15s
esphome:
#friendly_name: S2 mini Bureau
esp32:
board: esp32-s2-saola-1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "YZB2TqDdQeJSvRhgjgjlgfgYk8PMU/vJ9ZX7SYYQ="
ota:
password: "f24b03fc24c98464465d35422bd867"
packages:
device_base: !include tools/device_base.yaml
wifi: !include tools/ip_fixe.yaml
wifi:
networks:
# - ssid: !secret wifi_chalet
# password: !secret wifi_chalet_pwd
- ssid: !secret wifi_domotique
password: !secret wifi_domotique_pwd
# - ssid: !secret wifi_maison
# password: !secret wifi_maison_pwd
# - ssid: !secret wifi_Me
# password: !secret wifi_Me_pwd
ap:
ssid: "S2-Mini-Bureau Fallback Hotspot"
password: "yyrfKkhkhxV"
captive_portal:
uart:
tx_pin: 18
rx_pin: 33
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
binary_sensor:
- platform: ld2410
has_target: #Présence
has_moving_target: #Cible mobile
has_still_target: #Cible immobile
out_pin_presence_status:
name: Out Pin Presence Status
- platform: gpio
pin: 16
name: gpio out pin presence
switch:
- platform: ld2410
engineering_mode:
- platform: ld2410
light: #intensité lumineuse
moving_distance: #distance cible en mouvement
still_distance: #distance cible immobile
moving_energy: #quantité de mouvement
still_energy: #quantité d'immobilité ??
detection_distance: #distance de détection
number:
- platform: ld2410
timeout: #Temps pour passer le binary sensor Présence à faux
light_threshold: #Seuil de lumière
name: light threshold
max_move_distance_gate: #Distance de détection du mouvemenet 2-8
name: max move distance gate
max_still_distance_gate: #Distance de détection d'immobilité 2-8
name: max still distance gate
button:
- platform: ld2410
restart:
select:
- platform: ld2410
distance_resolution:
name: Distance Resolution> Blockquote
status_led:
pin:
number: GPIO15
inverted: True
