I’m trying to make my first blueprint
This simple blueprint will regulate a switch based on a temperature sensor
I have an issue … but I don’t know where is the problem …
Could you help me ?
blueprint:
name: Heating Virtual Thermostat
description: Regulating of an electrical heater connected to a switch using a temperature
sensor
domain: automation
input:
sensor_temperature:
description: This dector will be used for the regulation
selector:
entity:
domain: sensor
device_class: temperature
target_switch:
description: Actuator to be controled
selector:
entity:
domain: switch
source_url: https://github.com/PITP2/Blueprints/blob/606e2effeb1029072e52f0c8232f9601a841ee9a/Thermostat%20virtuel
- platform: numeric_state
entity_id: !input 'sensor_temperature'
above: '21'
below: '20'
- choose:
- conditions:
- condition: numeric_state
below: '20'
sequence:
- service: switch.turn_on
entity_id: !input 'target_switch'
- conditions:
below: '21'
sequence:
- service: switch.turn_off
default:
mode: single
> 2020-12-27 16:28:52 INFO (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] Heating Virtual Thermostat: Running automation actions
> 2020-12-27 16:28:52 INFO (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] Heating Virtual Thermostat: Choose at step 1: choice 2: Running automation actions
> 2020-12-27 16:28:52 INFO (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] Heating Virtual Thermostat: Choose at step 1: choice 2: Executing step call service
> 2020-12-27 16:28:52 ERROR (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] Heating Virtual Thermostat: Choose at step 1: choice 2: Error executing script. Invalid data for call_service at pos 1: not a valid value for dictionary value @ data['entity_id']
> 2020-12-27 16:28:52 ERROR (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] Heating Virtual Thermostat: Error executing script. Invalid data for choose at pos 1: not a valid value for dictionary value @ data['entity_id']
> 2020-12-27 16:28:52 ERROR (MainThread) [homeassistant.components.automation.heating_virtual_thermostat] While executing automation automation.heating_virtual_thermostat
> Traceback (most recent call last):
> File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 404, in async_trigger
> await self.action_script.async_run(
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1026, in async_run
> await asyncio.shield(run.async_run())
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 242, in async_run
> await self._async_step(log_exceptions=False)
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
> await getattr(
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 596, in _async_choose_step
> await self._async_run_script(script)
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 670, in _async_run_script
> await self._async_run_long_action(
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 419, in _async_run_long_action
> long_task.result()
> await getattr(
> File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 457, in _async_call_service_step
> await service_task
> File "/usr/src/homeassistant/homeassistant/core.py", line 1399, in async_call
> processed_data = handler.schema(service_data)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 218, in __call__
> return self._exec((Schema(val) for val in self.validators), v)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 340, in _exec
> raise e if self.msg is None else AllInvalid(self.msg, path=path)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/validators.py", line 336, in _exec
> v = func(v)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
> return self._compiled([], data)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 817, in validate_callable
> return schema(data)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
> return base_validate(path, iteritems(data), out)
> File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
> raise er.MultipleInvalid(errors)
> voluptuous.error.MultipleInvalid: not a valid value for dictionary value @ data['entity_id']
