Issue with trigger.to_state in automation -> UndefinedError: 'trigger' is undefined
I’ve got
- alias: Devices disconnected
    platform: state
    entity_id:
    - device_tracker.ipcam1
    - device_tracker.ipcam2
    to: 'not_home'
    for:
      minutes: 1
    service: notify.ha_telegram
      message: "{{ trigger.to_state.attributes.friendly_name }} is now {{ trigger.to_state.state }} since a few minutes"
and I am getting the error below when a device goes offline
jinja2.exceptions.UndefinedError: ‘trigger’ is undefined
I’m not triggering it manually, I just disconnected one of the devices to test the automation.
Any idea of what could be wrong ?
I Think its to do with the formating
    platform: state
    entity_id:
    to: 'not_home'
    for:
      minutes: 1
I think the
need 2 more spaces in the line
Hi Myle, I’ve tried and got the exact same error.
This is the full log, when the automation gets triggered
2018-06-10 18:28:16 INFO (MainThread) [homeassistant.components.automation] Executing Devices disconnected
2018-06-10 18:28:16 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: name=Devices disconnected, message=has been triggered, domain=automation, entity_id=automation.devices_disconnected>
2018-06-10 18:28:16 INFO (MainThread) [homeassistant.helpers.script] Script Devices disconnected: Running script
2018-06-10 18:28:16 INFO (MainThread) [homeassistant.helpers.script] Script Devices disconnected: Executing step call service
2018-06-10 18:28:16 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=notify, service=ha_telegram, service_data=message={{ trigger.to_state.attributes.friendly_name }} is now {{ trigger.to_state.state }} since a few minutes, service_call_id=1972315152-5>
2018-06-10 18:28:16 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.ha_telegram: message=<homeassistant.helpers.template.Template object at 0x701bd7f0>>
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/template.py", line 132, in async_render
    return self._compiled.render(kwargs).strip()
  File "/usr/lib/python3.6/site-packages/jinja2/asyncsupport.py", line 76, in render
    return original_render(self, *args, **kwargs)
  File "/usr/lib/python3.6/site-packages/jinja2/environment.py", line 1008, in render
    return self.environment.handle_exception(exc_info, True)
  File "/usr/lib/python3.6/site-packages/jinja2/environment.py", line 780, in handle_exception
    reraise(exc_type, exc_value, tb)
  File "/usr/lib/python3.6/site-packages/jinja2/_compat.py", line 37, in reraise
    raise value.with_traceback(tb)
  File "<template>", line 1, in top-level template code
  File "/usr/lib/python3.6/site-packages/jinja2/sandbox.py", line 385, in getattr
    value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'trigger' is undefined
  File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1007, in _event_to_service_call
    await service_handler.func(service_call)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 134, in async_notify_message
    kwargs[ATTR_MESSAGE] = message.async_render()
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/template.py", line 134, in async_render
    raise TemplateError(err)
homeassistant.exceptions.TemplateError: UndefinedError: 'trigger' is undefined
I tried
"{{ trigger.to_state.attributes.friendly_name }}"
"{{ trigger.to_state.state }}"
"{{ trigger.to_state.attributes }}"
all 3 give
And I also tried to replace
to: 'not_home'
for:
  minutes: 1
with
to: 'not_home'
Same issue
You need data_template instead of data in the action.
Genius ! That worked.
Thanks.
Best part of the documentation :
Remembering these simple rules will help save you from many headaches and endless hours of frustration when using automation templates.
Hi
I also have:
- alias: 'SensoresPOW'
    - platform: state
      entity_id:
        - sensor.pow001
        - sensor.pow002
        - sensor.pow003
        - sensor.pow004
        - sensor.pow005
  condition:
    - condition: template
      value_template: '{{ trigger.to_state.state != trigger.from_state.state }}'
#      to: 'on'
    service: notify.NotifySensors
    data_template:
      message: >
          {% set data = as_timestamp(now()) | timestamp_custom("%d/%m/%y", True) %}
          {% set time = as_timestamp(now()) | timestamp_custom("%H:%M:%S", 0) %}
          {% set sens = trigger.to_state.attributes.friendly_name %}
          {% set stat = trigger.to_state.state %}
          {{ data }};{{ time }};{{ sens }};{{ stat }}
and the same error: ‘trigger’ is undefined.
What am I doing wrong Can anyone help me!
Thanks.
Did you resolve?
I have the same problem.
Thanks!
Hi
I didn’t found the solution.
I have not solved the problem yet. I had to solve other more important situations. is not forgotten is in the “to do”
Hi
Remove the .attributes. from your message
This is my code:
  - alias: "NOTIFY: Offline GPS Device"
    initial_state: true
      platform: state
      entity_id:
        - group.device_tracker_location
      - service: automation.trigger
        entity_id: automation.snapshot_device_location
      - service: notify.jeeves_telegram
        data_template:
          message: "{{ trigger.to_state.name }} Status change: {{ trigger.to_state.state }}"
Note: my sensor does not have a friendly_name and thus I’m using “name”
Note2: Remember to always have data_template: when using automaion with states and attributes.
This is my result:
Please also remember that when you manually fire off the automation the trigger values will not be available!
