Issue with two identical generic camera's
Hello all,
I’m quite new to HA and I’m having issues with one of my two identical IP camera’s. They are both D-link DCS-820L camera’s. One of the two camera’s is working without a problem, but the other one is unable to connect. I checked my configuration and it is identical to the other camera. Also when I use the link in a browser with the same credentials it is working.
Does anyone have a tip?!
how are you configuring them. Post your yaml.
When you say identical configuration, I hope you are not saying the ip addresses are the same.
Off course the IP addresses are different. Also the credentials are. But when I use the exact details in a browser it works.
Sorry, I always check the obvious first… it’s usually the little stuff that gets ya. I believe that cam has a cat5 ethernet port. I’ve seen a lot of problems due to wifi connectivity. Can you plug the puppy in and try it?
Post your yaml.
This is the YAML code I’m using:
  - platform: generic
    name: Camera Kamer Daan
    still_image_url: http://192.168.0.251/image/jpeg.cgi
    username: admin
    password: *****
  - platform: generic
    name: Camera Kamer Luuk
    still_image_url: http://192.168.0.252/image/jpeg.cgi
    username: admin
    password: *****
