Issue with weather in 2023.8
Hi All,
I know this was an issue with in the BETA release of 2023.8 - but I’ve just updated from 2023.7.3 to 2023.8.1 and I am getting the same issue with the weather that others were reporting, where the card isn’t rendering properly - and just showing ‘day’ - this is happening across multiple different devices. I’m using the OpenWeatherMap integration.
Is there a known fix for this at the moment, or is it due in a future point release?
Leacho
Have you tried clearing your web browser cache?
Hi Tom,
Yes, I have cleared the cache - I have also tried in an ‘in private’ window, and have the same results.I have rebooted the Home Assistant OS server also - same results.
Leacho
You should report it as a new issue then.
Issue Raised: Issue with Weather Card since 2023.8 · Issue #17496 · home-assistant/frontend · GitHub
