My issue is:
My Raspberry Pi connects on my Wifi at the first boot so that’s great, I’ve seen the web page installation process and I’ve created my account and logged in but about 2-3 minutes the Raspberry losts the Wifi connection and I cannot explain why.
I’ve plugged an RJ45 to get an access and in the Supervisor / System / Host the Wifi parameters are correctly configured with my parameters entered in the “my-network” file.
I reboot the Host with Wifi enabled and RJ45 plugged and the Pi get 2 IP addresses reachabled (RJ45 and Wifi) by ping and web access on port 8123 but when I unplug the RJ45 I lost connection on both while the Wifi connection should stay connected …
If I plug the RJ45 back, both connections are UP.
Do you have an idea about this issue?
I’ve already changed the Raspberry Pi, also tried to add a Wifi USB device but that bring me more issues like if I disable the Wifi internal card that’s disable both Wifi Internal and USB…
Just wanted to chime in and say I’ve got the same issues here after upgrading last night and then again this morning after restoring my previous setup.
