Issue with Zigbee2MQTT Pairing - Sonoff Zigbee 3.0 Dongle Plus
Hello everyone,
I’m having trouble pairing Zigbee devices with Zigbee2MQTT. Despite multiple attempts and checks, my Sonoff Zigbee 3.0 USB Dongle Plus appears to be detected, and Zigbee2MQTT starts without issues. However, no devices are joining the network, even when pairing mode is enabled. :disappointed:
:desktop_computer: My setup:
  • Home Assistant OS (HAOS)
  • Zigbee2MQTT Add-on installed from the official repository (45df7312_zigbee2mqtt)
  • Mosquitto MQTT Add-on installed and working
  • USB Dongle: Sonoff Zigbee 3.0 USB Dongle Plus (CC2652P-based)
  • Zigbee2MQTT version: 2.0.0
  • zigbee-herdsman version: 3.2.1
  • Dongle firmware: zStack3x0 20210708
:round_pushpin: Zigbee2MQTT Configuration (excerpt)
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://core-mosquitto:1883
  user: mqtt
  password: XXXXXXX
serial:
  adapter: zstack
  port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6e02b54d23b6ed11a9ebe10ea8669f5d-if00-port0
advanced:
  log_level: debug
  channel: 15
  network_key: GENERATE
permit_join: true
frontend:
  port: 8099
:mag: What is working:
:white_check_mark: The dongle is detected properly:
ls -l /dev/serial/by-id/
# Output:
usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6e02b54d23b6ed11a9ebe10ea8669f5d-if00-port0 -> ../../ttyUSB0
:white_check_mark: Zigbee2MQTT starts successfully:
ha addons logs 45df7312_zigbee2mqtt
[info] Zigbee2MQTT started!
[info] Connected to MQTT server
:white_check_mark: Mosquitto MQTT is running and Zigbee2MQTT is connected:
mosquitto_sub -h core-mosquitto -u mqtt -P XXXXXXX -t zigbee2mqtt/bridge/state
{"state":"online"}
:white_check_mark: Pairing mode activation works:
mosquitto_pub -h core-mosquitto -u mqtt -P XXXXXXX -t zigbee2mqtt/bridge/request/permit_join -m '{"value":true, "time":255}'
[info] Zigbee: allowing new devices to join.
:rotating_light: What is NOT working:
:red_circle: Unable to pair any Zigbee device
Even when putting a device into pairing mode, no new devices appear in Zigbee2MQTT.
:red_circle: No pairing attempt logs in MQTT
When running:
mosquitto_sub -h core-mosquitto -u mqtt -P XXXXXXX -t zigbee2mqtt/#
I see no connection attempts from new devices.
:red_circle: “Invalid Payload” MQTT Error at first
Initially, when I tried:
mosquitto_pub -h core-mosquitto -u mqtt -P XXXXXXX -t zigbee2mqtt/bridge/request/permit_join -m '{"value":true}'
I got this error in the Zigbee2MQTT web interface:
z2m: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'Invalid payload'
Since adding "time":255 to the command, pairing mode activates successfully, but devices still won’t join.
:wrench: Steps I have tried:
  1. Verified Zigbee2MQTT is running:white_check_mark: OK
  2. Checked MQTT connection:white_check_mark: OK (mosquitto_sub works)
  3. Confirmed the dongle is detected:white_check_mark: OK (ls -l /dev/serial/by-id/)
  4. Restarted the USB dongle & Zigbee2MQTT:white_check_mark: OK
  5. Tried switching Zigbee channel (from 15 to 25):no_entry_sign: No pairing
  6. Reset the Zigbee device (long press + full reset):no_entry_sign: No pairing
  7. Tried different USB ports for the dongle:no_entry_sign: No improvement
  8. Disabled & re-enabled permit_join + HA restart:no_entry_sign: Still nothing
:pushpin: Questions for Zigbee2MQTT experts:
  1. Why do I see no device connection attempts in MQTT logs?
  2. Did I miss any steps to enable device pairing?
  3. Could this be a compatibility issue with certain Zigbee devices?
  4. Could my dongle be misflashed? Should I reflash with a different firmware?
  5. Are there any specific parameters to test in configuration.yaml?
Thanks in advance for your help! :blush: Any suggestions are welcome.
I can provide additional logs or run specific commands if needed. :bulb:
  • Zigbee2MQTT Add-on installé via le repository officiel (45df7312_zigbee2mqtt)
  • Mosquitto MQTT Add-on installé et fonctionnel
  • Dongle USB : Sonoff Zigbee 3.0 USB Dongle Plus (basé sur CC2652P)
  • Version de Zigbee2MQTT : 2.0.0
  • Version de zigbee-herdsman : 3.2.1
  • Firmware du dongle : zStack3x0 20210708
version core-2025.1.4
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.13.1
os_name Linux
os_version 6.6.62-haos-raspi
arch aarch64
timezone Europe/Paris
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
HACS Data ok
GitHub API Calls Remaining 5000
Installed Version 2.0.4
Stage running
Available Repositories 1505
Downloaded Repositories 22
AccuWeather
can_reach_server ok
remaining_requests 33
Home Assistant Cloud
logged_in true
subscription_expiration 31 août 2025 à 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled true
cloud_ice_servers_enabled true
remote_server eu-central-1-13.ui.nabu.casa
certificate_status ready
instance_id b4b8335cfd294451a88beb93010fa9b8
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 14.2
update_channel stable
supervisor_version supervisor-2024.12.3
agent_version 1.6.0
docker_version 27.2.0
disk_total 116.5 GB
disk_used 55.9 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi5-64
supervisor_api ok
version_api ok
installed_addons Terminal & SSH (9.16.0), AdGuard Home (5.2.3), File editor (5.8.0), Linky (1.5.0), go2rtc (1.9.8), ESPresense Companion (1.0.15), AppDaemon (0.16.7), Studio Code Server (5.18.1), Spotify Connect (0.13.0), Frigate (0.14.1), NGINX Home Assistant SSL proxy (3.11.1), RPC Shutdown (2.5), Grafana (10.2.2), Jellyfin NAS (10.10.4), Jellyseerr (2.3.0), Radarr (5.17.2.9580), Sonarr (4.0.12.2866), qBittorrent (5.0.3), FlareSolverr (3.3.21), Jackett NAS (0.22.1309), OpenVPN Client (0.2.9), Mosquitto broker (6.5.0), Zigbee2MQTT (2.0.0-2)
Dashboards
dashboards 2
resources 11
views 15
mode storage
Recorder
oldest_recorder_run 18 janvier 2025 à 02:40
current_recorder_run 30 janvier 2025 à 23:13
estimated_db_size 384.89 MiB
database_engine sqlite
database_version 3.47.1
Spotify
api_endpoint_reachable ok
___
Have you tried an extension USB on dongle?
Yes i use it
What devices are you trying to pair?
For those who come after me:
  • I reflashed the firmware of the dongle (back to USB mode).
  • Updated the config as follows:
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  user: mqtt
  password: XXXXX
serial:
  port: >-
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_xxxxxxxxxxxxxxxxxxxxxx5d-if00-port0
  adapter: zstack
homeassistant: true
permit_join: false
advanced:
  log_level: debug
  pan_id: GENERATE
  ext_pan_id: GENERATE
  channel: 25
frontend:
  port: 8099
devices: {}
experimental:
  new_api: true
My devices were not immediately recognized, except for one that showed an error…
  • A quick system reboot, and everything is working now :slightly_smiling_face:
