I am facing issue with zigbee2mqtt to connect an Aqara door contact ( Xiaomi MCCGQ11LM), The first try I was lucky and it was discovered correctly and appeared on my home assistant (Hassio). While changing the the name of the device it sudenly dissapeared. I now tries million ways to add it again with no avail.
However, now I can see only one entity which is the link quality appears and I cannot configure it because it does not have a unique ID!! Maybe from the time I tried to add the sensor from configuration.yaml.
I already have two other Door contacts same model connected through the same zigbee2mqtt they work fine and if I delete them they will be discovered again.
From the log of the zigbee2mqtt I see that the Door contact in question is paired and getting updates:
Zigbee2MQTT:info 2020-09-03 18:42:22: MQTT publish: topic 'zigbee2mqtt/0x00158d00041a3afa', payload '{"battery":91,"contact":false,"linkquality":36,"voltage":2985}'
From My home assistant I can see that the topic reaches it when I listen to the topic (zigbee2mqtt/0x00158d00041a3afa)
I get a message:
Message 0 received on zigbee2mqtt/0x00158d00041a3afa at 6:55 PM:
"battery": 91,
"contact": true,
"linkquality": 26,
"voltage": 2985
The zigbee2mqtt configuration:
data_path: /share/zigbee2mqtt
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://192.168.8.5:1883'
user: xxxxxx
password: xxxxxxx
serial:
port: >-
/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CCE253C-if00
advanced:
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blacklist: []
ban: []
whitelist: []
queue: {}
socat:
enabled: false
master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
restartdelay: 1
initialdelay: 1
options: '-d -d'
log: false
device_options:
retain: true
The MQTT section from my Home Assistant:
mqtt:
discovery: true
discovery_prefix: homeassistant
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
