I just begin my journey with HomeAssistant ifso please take that into consideration
I installed VM on DSM 7.0 beta the Home Assistant Supervised from image version hassos-5-13-ova.
The process itself seems to be easily, I setup everything giving relevant resources (1CPU, 3Gb of RAM). The VM is starting well, initialization process as well and the issue starts here. No matter if I asses through the http://homeassistant.local:8123 or ip:8123 the interface is working dramatically slow, from time to time there is only blank page visible or error message like: âerror to load configuration or error to load add onsâ.
Here is the piece of log from http server:
Logger: aiohttp.server Source: /usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py:393 First occurred: 22:22:53 (1 occurrences) Last logged: 22:22:53
File âaiohttp/_http_parser.pyxâ, line 546, in aiohttp._http_parser.HttpParser.feed_data* aiohttp.http_exceptions.BadStatusLine: 400, message=âBad status line âinvalid HTTP methodââ
And in addition from Supervisor => System => Core:
I am not sure is above description is clear enough to help me to find out what is the issue with the performance and strange behavior of the gui interface.
Hi again,
thank you you found time and went through the issue I have.
Answering your questions:
such behavior of the system is visible right after installation if so I can tell there are no add-ons at all. The issue is mostly visible in Supervisor tab or during the login. It takes really long time to load and from time to time is blank page " Error while loading page hassio." or even before put credentials
In regards to chassis I am even not able to check because I cannot access hassio tab itâs continuously loading
I already have tried many ways of running it. First I started from downloading *.ova image and run it as VM using Synology Virtual Machine Manager. Issues as described. Yesterday I decided to download pure Debian 10 image and visualize it on Synology. Then I installed Docker and hass.io using the script.
Current dockers which are running:
root@debian-ha:/home/kalatos# sudo docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
781e619891fc homeassistant/amd64-addon-configurator:5.2.0 â/initâ 13 hours ago Up 13 hours addon_core_configurator
9e75d7db8c10 ghcr.io/hassio-addons/ssh/amd64:8.2.0 â/initâ 13 hours ago Created addon_a0d7b954_ssh
baa9eaf19aaa homeassistant/amd64-addon-samba:9.3.1 â/initâ 13 hours ago Up 13 hours addon_core_samba
c589164cecbe homeassistant/amd64-hassio-multicast:2021.04.0 â/initâ 13 hours ago Up 13 hours hassio_multicast
7f7591415d3d homeassistant/amd64-hassio-cli:2021.03.1 â/init /bin/bash -c âŚâ 13 hours ago Up 13 hours hassio_cli
dc0c7ebf5ee4 homeassistant/amd64-hassio-audio:2021.02.1 â/initâ 13 hours ago Up 13 hours hassio_audio
fb7da3efd5a4 homeassistant/amd64-hassio-dns:2021.01.0
After refreshing browser many times it starts to work for a while but then same issues.
I manage to buy additional 8GB of RAM on my Synology DS218plus so for sure this is not issue with RAM as I have at latest 4GB. What about CPU? I donât know. According to the manuals I gave only one CPU keeping second one for DSM itself. I am considering if the CPU upgrde might be the solution but before invest any money I would like to make sure this will be it. Could you please tell your experience while hosting hass.io od Synology, how many CPU you give.
The utilization of the CPU and RAM is relatively small:
@fredrike do you plan to release hass.io package for DSM7 in the short period of time?
according to the browsers I have tried on Firefox, Chrome, EDGE Chromium. For all the browsers same behavior
Is there any other place either on Debian or HA I can look the log file and see what is happening?
I would like to start with the integrations but for such unstable environment I cannot. I really do not have idea what more can I check now.
If you could share your voice and experience I will be really grateful!
Yesterday I gave additional CPU for Debian VM but no difference into hass.io behaviour
Is there any place that I can get the logs ex. from Debian in order to try to troubleshot?
At the end I will be enforced to by micro computer and make the virtualisation there but better if I will be able to use the Synology device I already have - for sure it will be cheaper solution
What is wired here nobody has his instance on DS218plus in order to share his experience?
Donât get me wrong, but you are running VMM on unsupported machine (218play with Realtek processor) on BETA version od DSM 7âŚ
As a matter of fact - even Docker is not supported on play (or j) series of Synology.
Sorry - forgot how to read Normally itâs 218+ and 218play, so when Iâve just seen p thought itâs play
What version of VMM are you on - 2.5.3-11366 is latest?
Also, just to repeat - DSM 7 is in BETA and is not suppoed to be run except for experimental use⌠Even when it is released, I suggest that you wait few months before upgrading to it.
thanks for prompt answer! The version is latest 2.5.3-11366.
I regret updating DSM for several reasons but so far as I understood there is no rollback option and should be stable version soon.
Do you have any other ideas what to check?
Is that possible to install Supervised on Docker instance available in the build in images?
when It comes into the description what is wrong with the HA console. Well slow work is felt, switching between options in the menu takes time. Especially when I try to enter Supervisor tab - one time it loads right after I click into it but most of the time while clicking continuous loading and blank page.
Same with login page. One time when I try to access HA console login menu and login process takes at latest 3 seconds. Next time I am struggling with this wired message like Initializing or loading content - I pestle screen shots few posts above.
seems there is no UFW on my debian instance:
root@debian-ha:/home/kalatos# ufw status bash: ufw: command not found root@debian-ha:/home/kalatos# ufw bash: ufw: command not found root@debian-ha:/home/kalatos# ufw disable
