Hi
I’m trying to add an Heinan Temperature & Humidity sensor but even if the adding of the device seems to work I end up with Manufacturer/Model unknown. Note that this device was actually added to HA earlier and I did receive temperature readings from the device but after an full reinstall of the device I’m not able to see any info from it.
I’m running an minimal installation on Rpi4 64-bit using Z-Wave JS 0.1.6. I can see the following info in the log:
15:00:05.220 CNTRLR starting inclusion process...
15:00:05.261 CNTRLR handling add node request (status = Ready)
15:00:05.261 CNTRLR the controller is now ready to add nodes
15:00:07.832 CNTRLR handling add node request (status = NodeFound)
15:00:08.063 CNTRLR handling add node request (status = AddingSlave)
15:00:08.473 CNTRLR handling add node request (status = ProtocolDone)
15:00:08.475 CNTRLR stopping inclusion process...
15:00:08.624 CNTRLR handling add node request (status = Done)
15:00:08.626 CNTRLR done called for 26
15:00:08.629 CNTRLR finished adding node 26:
basic device class: Routing Slave
generic device class: Multilevel Sensor
specific device class: Routing Multilevel Sensor
supported CCs:
· Basic (0x20)
· Multilevel Sensor (0x31)
· Z-Wave Plus Info (0x5e)
· Association (0x85)
· Multi Channel Association (0x8e)
· Association Group Information (0x59)
· Transport Service (0x55)
· Version (0x86)
· Manufacturer Specific (0x72)
· Device Reset Locally (0x5a)
· Powerlevel (0x73)
· Battery (0x80)
· Security 2 (0x9f)
· Wake Up (0x84)
· Supervision (0x6c)
controlled CCs:
15:00:08.631 CNTRLR » [Node 026] Assigning return route to controller...
15:00:08.649 CNTRLR the inclusion process was stopped
15:00:09.522 CNTRLR [Node 026] Configuring Z-Wave+ Lifeline association...
15:00:09.703 CNTRLR [Node 026] WakeUpCC: doing a complete interview...
15:00:09.704 CNTRLR » [Node 026] retrieving wakeup capabilities from the device...
15:00:09.783 CNTRLR « [Node 026] received wakeup capabilities:
default wakeup interval: 86400 seconds
minimum wakeup interval: 60 seconds
maximum wakeup interval: 86400 seconds
wakeup interval steps: 60 seconds
15:00:09.784 CNTRLR » [Node 026] retrieving wakeup interval from the device...
15:00:09.846 CNTRLR « [Node 026] received wakeup configuration:
controller node: 0
15:00:09.848 CNTRLR » [Node 026] configuring wakeup destination node
15:00:09.898 CNTRLR [Node 026] wakeup destination node changed!
15:00:09.901 CNTRLR [Node 026] Beginning interview - last completed stage: None
15:00:09.903 CNTRLR [Node 026] new node, doing a full interview...
15:00:09.904 CNTRLR » [Node 026] querying protocol info...
15:00:09.943 CNTRLR « [Node 026] received response for protocol info:
is a listening device: false
is frequent listening: false
is a routing device: true
is a secure device: unknown
is a beaming device: true
maximum baud rate: 40000 kbps
version: 4
15:00:09.946 CNTRLR [Node 026] The node is now asleep.
15:00:09.956 CNTRLR [Node 026] Interview stage completed: ProtocolInfo
15:00:09.957 CNTRLR » [Node 026] querying node info...
Any idea what is wrong here?
