Issues after 0.85.1 - SOLVED!
I have this template that were working perfectly before upgrading to 0.85.1
- service: tts.google_say
  data_template:
    entity_id: media_player.googlehome0461
    message: >-
      {% if now().strftime("%H")|int < 12 %}
      Buongiorno.
      {% elif now().strftime("%H")|int < 18 %}
      Buon Pomeriggio.
      {% else %}
      Buonasera.
      {% endif %}
      Meteo ed Agenda.
      Oggi il sole è sorto alle ore {{states.sensor.sunrisetoday.state}} e tramonterà alle ore {{states.sensor.sunsettoday.state}}.
      Il tempo è {{states.sensor.dark_sky_summary.state}} con {{states.sensor.dark_sky_temperature.state|round}} gradi.
      Oggi sarà {{states.sensor.dark_sky_hourly_summary.state|replace(".", "")}},
      temperatura massima: {{states.sensor.dark_sky_daytime_high_temperature_0.state|round}} gradi,
      temperatura minima: {{states.sensor.dark_sky_overnight_low_temperature_0.state|round}} gradi.
      Venti da {{states.sensor.pws_wind_dir_2.state
      |replace("N","Nord ")
      |replace("S","Sud ")
      |replace("E","Est ")
      |replace("O","Ovest ")
      }} a {{states.sensor.pws_wind_1d_kph_2.state}} km/h con raffiche fino a {{states.sensor.pws_wind_gust_kph.state|round}} km/h.
      Probabilità di pioggia: {{states.sensor.pws_precip_1d_2.state | int(0)}}%.
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.xxxigmailcom.attributes.start_time).split(" ")[0] and states.calendar.xxxgmailcom.attributes.all_day != True %} Prossimo appuntamento in Agenda: {{states.calendar.xxxgmailcom.attributes.message}} at {{(states.calendar.xxxgmailcom.attributes.start_time).split(" ")[1].split(":")[0]}} {%if (states.calendar.xxxgmailcom.attributes.start_time).split(" ")[1].split(":")[1] != '00'%}{{(states.calendar.xxxgmailcom.attributes.start_time).split(" ")[1].split(":")[1]}} {%endif%} {%endif%}
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.xxxgmailcom.attributes.start_time).split(" ")[0] and states.calendar.xxxgmailcom.attributes.all_day == True %} Oggi è: {{states.calendar.xxxgmailcom.attributes.message|replace("/","and")}}{%endif%}
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.inter_calendar.attributes.start_time).split(" ")[0] and states.calendar.inter_calendar.attributes.all_day != True %} Prossimo appuntamento in agenda: {{states.calendar.inter_calendar.attributes.message}} alle {{(states.calendar.inter_calendar.attributes.start_time).split(" ")[1].split(":")[0]}} {%if (states.calendar.inter_calendar.attributes.start_time).split(" ")[1].split(":")[1] != '00'%}{{(states.calendar.inter_calendar.attributes.start_time).split(" ")[1].split(":")[1]}} {%endif%} {%endif%}
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.inter_calendar.attributes.start_time).split(" ")[0] and states.calendar.inter_calendar.attributes.all_day == True %} Oggi è: {{states.calendar.inter_calendar.attributes.message|replace("/","and")}}{%endif%}
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.contacts.attributes.start_time).split(" ")[0] and states.calendar.contacts.attributes.all_day != True %} Prossimo appuntamento in agenda: {{states.calendar.contacts.attributes.message}} alle {{(states.calendar.contacts.attributes.start_time).split(" ")[1].split(":")[0]}} {%if (states.calendar.contacts.attributes.start_time).split(" ")[1].split(":")[1] != '00'%}{{(states.calendar.contacts.start_time).split(" ")[1].split(":")[1]}} {%endif%} {%endif%}
      {% if as_timestamp(now()) | timestamp_custom('%Y-%m-%d') == (states.calendar.contacts.attributes.start_time).split(" ")[0] and states.calendar.contacts.attributes.all_day == True %} Oggi è: {{states.calendar.contacts.attributes.message|replace("/","and")}}{%endif%}
      Tempo di percorrenza per Roma {{ states.sensor.avezzanoroma.attributes.duration | int | round(0) }} Minuti
But now if i test it in template editor i get this error:
Error rendering template: UndefinedError: 'None' has no attribute 'attributes'
What is changed in 0.85.1 ? How to fix?
EDIT: Solved !
The change was in the name of the sensor.avezzanoroma that is changed into sensor.avezzano_roma. I think it’s a breaking change butb i did not read anything about it in the changelog of 0.85.1.
You must be kidding?
It’s the very first sentance of the release notes:
Slugify changed, which can impact entity ID creation if the entities had names with either a - or characters outside of A-Z and the integration has no unique IDs. We now better handle the characters and substitute it with an alternative instead of removing that character.
Very difficult to understand for a non-english user…
I got bitten by this same change. The wording in the breaking change descriptions says this is on ID Creation, so while it may be clear to some, the wording is less than clear. My mqtt devices, which already existed were renamed, so I had to go through and clean up id’s and any refefences to thos id’s.
