I have no idea what caused this, just upgraded now I’m seeing a ton of errors also Logbook and history do not load.
The first error says this:
Invalid config
The following integrations and platforms could not be set up:
- history
- logbook
- default_config
Please check your config and logs.
Below are a few error logs:
Logger: homeassistant.components.recorder
Source: components/recorder/init.py:939
Integration: recorder (documentation, issues)
First occurred: 9:18:48 PM (10 occurrences)
Last logged: 9:24:30 PM
Error during connection setup to mysql://homeassistant:PASSWORD@core-mariadb/homeassistant?charset=utf8mb4: (MySQLdb._exceptions.OperationalError) (2005, “Unknown MySQL server host ‘PARTIALPASSWORD@core-mariadb’ (-3)”) (Background on this error at: http://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py”, line 3212, in _wrap_pool_connect
return fn()
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 301, in connect
return _ConnectionFairy._checkout(self)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 761, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 419, in checkout
rec = pool._do_get()
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/impl.py”, line 145, in do_get
self.dec_overflow()
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/util/langhelpers.py”, line 70, in exit
compat.raise(
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py”, line 207, in raise
raise exception
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/impl.py”, line 142, in _do_get
return self._create_connection()
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 247, in _create_connection
return _ConnectionRecord(self)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 362, in init
self.__connect()
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 605, in connect
pool.logger.debug(“Error on connect(): %s”, e)
compat.raise(
raise exception
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/pool/base.py”, line 599, in __connect
connection = pool._invoke_creator(self)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/create.py”, line 578, in connect
return dialect.connect(*cargs, **cparams)
File “/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py”, line 584, in connect
return self.dbapi.connect(*cargs, **cparams)
File “/usr/local/lib/python3.9/site-packages/MySQLdb/init.py”, line 130, in Connect
return Connection(*args, **kwargs)
File “/usr/local/lib/python3.9/site-packages/MySQLdb/connections.py”, line 185, in init
super().init(*args, **kwargs2)
MySQLdb._exceptions.OperationalError: (2005, “Unknown MySQL server host ‘#V!ax@core-mariadb’ (-3)”)
