Issues Connecting A9 Mini Wi-Fi Camera to iSpy and Streaming via RTSP
Hi everyone,
I’m having trouble connecting my A9 Mini Wi-Fi Camera to iSpy and getting the RTSP stream to work correctly. Here’s the setup I’ve tried:
  1. The camera is connected to my Wi-Fi network and I have confirmed its IP address (192.168.1.xx) using a network scanner.
  2. I’ve tried adding the camera in iSpy by selecting the RTSP stream option and entering the following URL:
  • rtsp://192.168.1.xx:554/stream1 (and similar variations like rtsp://192.168.1.xx:554/live).
  1. I have verified that the camera is reachable via ping, and the connection seems stable.
  2. When testing the connection in iSpy, I get an error saying it cannot connect or the video feed is not showing.
Has anyone successfully set up an A9 Mini Wi-Fi camera with iSpy? Are there any specific configuration settings I might be missing, or is there a known issue with the RTSP stream from this camera?
Also, has anyone tried using the MJPEG stream in iSpy? I’ve tried that as well with no luck.
Any help or suggestions would be much appreciated!
Thanks in advance!
