The problem is that this stops working after I reboot the PI / restart HA and the only way to fix it is to re add the node via HA (add node, press “learn”, wait for flashing lights to stop) as doing this it then suddenly starts working.
Any ideas?
btw - if it helps I found this in the “zwcfg_0xd0c7cb19.xml” for these three remotes:
I’m not seeing the “Manufacturer id” or “Product type” or much more of the gubbins (technical term) that we usually see for other zwave items.
UPDATE I’m also seeing the same behaviour in OSZWCP.
This is what its like after an add (or re-add with the same ID):
2016-09-29 20:06:58.051 Info, Node041, Received Scene Activation set from node 41: scene id=1 now. Sending event notification.
2016-09-29 20:06:58.052 Detail, Node041, Notification: SceneEvent
2016-09-29 20:06:58.052 Info, Notification: Scene Event Home d0c7cb19 Node 41 Genre basic Class NO OPERATION Instance 0 Index 0 Type bool Scene Id 1
and then restarting just the process it goes back to this:
I added the remotes (with the scene change) via OZWCP (also making sure to hit the “save” button to write the changes to the xml file!) and then making sure that the added Node ID with all it’s stuff gets copied over to the one used by HA.
I wonder if the scripted install should be changed so that they both share the same xml file ?
I also have a Key Fob DSA22, which I’m having trouble getting to work. I think I’ve managed to set it into scene mode by setting parameter 250 to 1. However when buttons are pressed there is not action to be found in the OZW_log.txt in the dir of HA (/home/hass/.homeassistant).
Also when looking at the “Current Entities” in HA I can’t find the Key Fob.
Hi, first post there, migrating from Veralite (no more supported) to HA, very happy with that! Able to migrate almost everything and also new devices like SMA, Xiaomi Vacuum, set up SSL and DuckDNS, THANKS ALL PEOPLE INVOLVED IN THIS PROJECT!
Already integrated Minimote, with the provided info on HA documentation, happy with that!
Now I’ve associated my DSA22 remote, but still do not know how to run scene with it. I think I modified 250 option to 1, like I did with Minimote, but not sure how to trigger a scene.
