Hi all,
I am using HP ProDesk 600 G4 Desktop Mini PC with
Home Assistant 2023.10.5
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
My device just randomly restarting on something between 5min - 30min. First I disabled all addons and it continues to restart. I restred Home Assistant and Supervisor to an older version and all was fine… It starts to reboot randomly after upgrade OS to version 11.0.
Below image shows last 3 hours.
I started with fresh new installation after wipe SSD and it is the same without any addons and without any sensor, script etc.
I got second HP ProDesk 600 G4 Desktop Mini PC and installed fresh installation and it is the same, always restarting after les than 30min. Probably it is not same issue on two different PC’s forcing them to restart.
Did anyone had similar issue? How did you solved it? Any suggestion or recommendation would be helpful.
Thank you in advance
In the meantime I disabled all automations, services, integrations and all entities. HA still rebooting all the time.
