Hi all,
Just now, I have the following config in place which works fine and I’m able to call the tts.google_translate_say
service and hear the output via the speaker.
tts:
- platform: google_translate
base_url: https://ha.mydomain.com:12121/
Both external_url
and internal_url
are set in the config.
homeassistant:
external_url: "https://ha.mydomain.com:12121/"
internal_url: "https://ha.mydomain.com/"
If I remove the base_url
from the config (as it’s now deprecated) and restart Home Assistant, the call to the tts.google_translate_say
service succeeds however I hear no output from the speaker.
When I view the state attributes from within Developer Tools, it shows the below with an idle
state:
media_content_id: >-
https://ha.mydomain.com/api/tts_proxy/xxxxxxxxx_en_-_google_translate.mp3
From what I can see, this is using the internal_url
(without the port number) whereas previously using the base_url
, it required me to use the same FQDN as I’ve set for the external_url
Is there a way for the tts integration to use the external_url
A few points to note:
- The domain ha.mydomain.com resolves to a public IP from the outside world however internal DNS resolves this to it’s private IP when inside the network hence both URLs are the same.
- I’m using SSL as per the config states therefore using an FQDN
- The certificate is signed by public CA (Let’s Encrypt) therefore no self-signed certs being used.
Any help would be appreciated.
Cheers,
Kev
