Issues using async_add_devices with update_before_add=True
Hi, I’m working on an integration. In sensor.py I have an async_setup_entry that looks like this:
async def async_setup_entry(hass, entry, async_add_devices):
    """Set up the sensor platform."""
    devices = [OccupancyEntity(
        entity_description=entity_description,
        client=hass.data[DOMAIN][entry.entry_id],
        location_name=location['name'],
    ) for (location, entity_description) in _get_location_description_pairs()]
    async_add_devices(devices, update_before_add=True)
The Occupancy#__init__() function sets self._attr_device_info like this:
        self._attr_device_info = DeviceInfo(
            identifiers={(DOMAIN, self.unique_id)},
            name=f"{location_name}",
This code creates 4 entities with DeviceInfo, so I’d expect 4 devices and 4 entities. When I install the integration, all 4 entities are created as expected, but only some get a device created as well (usually only 1, sometimes 2 or 3 get created as well - seems to be some sort of race condition).
Once it’s in this state, if I restart home assistant the devices get created as expected.
I have also tried the following:
  1. If I just do async_add_devices(devices) (no update_before_add) all devices and entities are created as expected, but obviously the state isn’t populated until the next poll interval, which isn’t ideal for my use case.
  2. I’ve tried calling async_add_devices once per device (with update_before_add). This results in similar behaviour (entities created but not all devices)
Does anybody have any ideas on how I can create these devices WITH initial data populated from the data source AND having all device registry entries created as expected?
I’m having a very similar situation with my custom integration. The only difference is I don’t have to restart HA but a browser refresh is enough to display the correct amount of devices and entities.
Did you find a solution to this issue?
