Hi all,
I’ve been searching around trying to find a solution to this, and not yet found one.
I apologise if there is a thread already.
I have been trying to create a template using sun.sun
attribute elevation. I have read it is better to use state_attr(‘sun.sun’,elevation) instead of states.sun.sun.attributes.elevation
. The issue is when I use state_attr
I always get the value none.
In developer tools I put these two lines in.
{{ state_attr('sun.sun',elevation)|float }}
{{ states.sun.sun.attributes.elevation|float }}
The result is:
0.0
36.2
When using {{ states.sun.sun.attributes.elevation|float }}
I get the correct value. When using {{ state_attr('sun.sun',elevation)|float }}
I get 0.0 and if I remove |float it will come back always as “None”.
I can get the automation to work using states.sun.sun.attirbutes.elevation
, but it has me puzzled why it does not work as state_attr
